Point of no return
Point of no return
After thinking about it for a year, I finally started my 1 Ton IFS swap.
The 1st cut is the hardest, especially on a good frame.
http://www.oldjeep.com/images/Ford/F...0305%20001.jpg
In that picture, the F350 frame is still about 12" longer than it needs to be. I wanted some time to consider the best way to graft the frames together. Think I have it figured out now, so by the end of next week the 2 parts should be one - straight and solid.
Chuck P
1953 F350
46 ****** 2a
www.oldjeep.com
Chuck P
1953 F350
46 ****** 2a
www.oldjeep.com
Originally Posted by oldjeep
It's going to be a lowered 2wd tow rig. Not a 4x4 of any sort.
I should have looked at the pic's closer. I just assumed you were going with the new trend of over sizing for Rock Crawling.
Originally Posted by IBeam
Now this is going to be Interesting. What are you going to be towing that needs that much Beef. I can only imagine what your Gear Ratio will be.
Why that much beef? Because it's a one ton truck and I want to keep the capacity. A car IFS doesn't quite cut it for a big truck
Got it all aligned last night and tacked in place. Should have a finished frame by end of next week.
