1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
09-03-2005, 11:30 PM
Boost Gauge Install Help
I just bought an Autometer Boost Gauge kit, and I need a little help. THe line that goes from the gauge to the T-Connector is 1/8". Where do I splice into to add the T-Connector? I can't find which line to cut. I can't even find one that is 1/8". Anyone know which is the "Boost" line?
Thanks,
DC-9
__________________
4 00-03 Ford F-350's, Diesel, Dually, Longbox.
2 2007 F-350's 6.0 diesel, dually, crewcab, lariat!
2 2005' Sterling Acterra dump's w/ 8yd Rugby Boxes
2001 Bobcat 763G Cab w-heat
2007 Bobcat A300, Cab w-heat and A/C
2007 Bobcat T300, Cab w- Heat and A/C
2006 John Deere 244J articulated wheel loader
2009 Mack Granite quad axle w/ OxBox 20yder
Sponsored Links
To remove this ad, register today!
09-03-2005, 11:47 PM
__________________
2001 F250 Lariat SC PSD SWB 4x4
09-04-2005, 12:02 AM
The line you want goes to the map sensor. It is on the top of the a/c condensor box on the passenger side.
__________________
Kevin SLEDPULLMOTORSPORTS
SPONSORED By
Air Flow Systems
Terminator Engineering
DI Performance, South Bend Clutch
Discount Power Parts, Grand Rock
09-04-2005, 03:58 AM
i just installed one of these on my SD. i used the black cloud diesel AIH delete plug. took all of about 2 min to install.
__________________
If it aint broke, fix it till it is.
02, 444ci, CC, LB, 4x4, w/ mods.
09-04-2005, 09:17 AM
Are we there yet?
Ditto on the AIH delete plug. Go that route, gets rid of that huge heater blocking intake air too.
Sooooo easy to install!!!!
__________________
2003 F250 PSD 7.3 LB 4X4, 6637, HPX, Coolant & Tran filters, a/c & CCV mods, ST9005 & 9007's, 203* thermo, Bilsteins, DiPricols, A-Pillar, Aux electric, more.
09-10-2005, 12:04 AM
AustinS- the link doesn't work.
Does anybody have a pic of where it is susposted to plug into?
DC-9
__________________
09-10-2005, 06:01 AM
DC-9
Copy and paste it into the address line. Otherwise you go to MoterHaven.
Picture is there.
My ISSPRO gauge came with the T fitting and tubing. Quick install, but it doesn't use clamps. It fits tight enough.
Frank
__________________
'02 F250 SD SB CC 7.3 PSD 4R100
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
