Pics/comparisons of the all the V10's Y-pipes
With all of the recent discussion of exhaust (specifically Y-pipes), I thought I'd put up some pics and give some info. Keep in mind that this is specific for the truck & SUV (sorry E-series guys). Also feel free to correct any mistakes I've made.
1999-2000 models came with the "rams horn" Y-pipe. It's oddly shaped and can exhibit a symptom known as "flutter". Flutter is just a noise caused by exhaust pulses traveling through the pipe. Still, the sound is kind of annoying.
For 2001-2004, Ford used a different Y-pipe that elminated (mostly) the flutter. However, this new design is extremely restrictive to flow. Personally, I'd rather have "flutter", but you can decide for yourself.
Here's a pic of the two Ford-designed Y-pipes:
http://makinhay.net/exhaust/ypipes.JPG
Not sure it shows how bad it is, but here's a close-up of the necked-down portion of the '01+ 2V 6.8L Y-pipe:
http://makinhay.net/exhaust/YNECK.JPG
Here's a pic of the Banks Powerpack "Y" compared to the 2001 Ford pipe:
http://makinhay.net/exhaust/ypipes2.JPG
Here are some pics of the '05 3-valve 6.8L Ford design. I guess the Excursion & Vans still have the 2V engine, so they may be different. Again, I'm no photographer, so I apologize for the poor pics ahead of time.
http://www.makinhay.net/exhaust/05ypipe2.JPG
http://www.makinhay.net/exhaust/05ypipe.JPG
Can't really tell because of all the heat shielding, but there aren't any severely "necked-down" areas of the piping.
Exlnt. I'm thinking through my options on my 2002 X right now. Probably going with the Banks. I bought my X used, already equipped with brake contrller and air bags, so I got to wondering if by chance that y pipe had been swapped out. No such luck. It is amazing how restrictive it is. Your pix are a great idea, but don't do the factory pipe the injustice it deserves. The restriction is not really visible. Any chance of a closeup of that section? If not, cool. I'm a professional photographer and when mine comes out, I'll shoot some pix. Thanks again for the side by side.
Later, I'll try to post some pics of the 2005 3V factory exhaust- which is MUCH better than past designs.
Best and most informative post I have seen in a while GREAT JOB Man I want to do it can you fill the differance???
