Pics/comparisons of the all the V10's Y-pipes - Ford Truck Enthusiasts Forums
Old 09-02-2005, 01:54 PM
NoMo's Avatar
NoMo NoMo is offline
NoMo is gaining momentum as a positive member of FTE.
Exclamation Pics/comparisons of the all the V10's Y-pipes
With all of the recent discussion of exhaust (specifically Y-pipes), I thought I'd put up some pics and give some info. Keep in mind that this is specific for the truck & SUV (sorry E-series guys). Also feel free to correct any mistakes I've made.
1999-2000 models came with the "rams horn" Y-pipe. It's oddly shaped and can exhibit a symptom known as "flutter". Flutter is just a noise caused by exhaust pulses traveling through the pipe. Still, the sound is kind of annoying.
For 2001-2004, Ford used a different Y-pipe that elminated (mostly) the flutter. However, this new design is extremely restrictive to flow. Personally, I'd rather have "flutter", but you can decide for yourself.
Here's a pic of the two Ford-designed Y-pipes:
http://makinhay.net/exhaust/ypipes.JPG
Not sure it shows how bad it is, but here's a close-up of the necked-down portion of the '01+ 2V 6.8L Y-pipe:
http://makinhay.net/exhaust/YNECK.JPG
Here's a pic of the Banks Powerpack "Y" compared to the 2001 Ford pipe:
http://makinhay.net/exhaust/ypipes2.JPG
Here are some pics of the '05 3-valve 6.8L Ford design. I guess the Excursion & Vans still have the 2V engine, so they may be different. Again, I'm no photographer, so I apologize for the poor pics ahead of time.
http://www.makinhay.net/exhaust/05ypipe2.JPG
http://www.makinhay.net/exhaust/05ypipe.JPG
Can't really tell because of all the heat shielding, but there aren't any severely "necked-down" areas of the piping.
Old 09-02-2005, 04:06 PM
NoMo's Avatar
I was just re-reading this and realized that I need to give some credit to Stan (Eurekaboy). I used his photo of the '99-'00 "rams horn" Y-pipe. Hope you don't mind Stan.
Old 09-02-2005, 05:01 PM
Monsta's Avatar
Monsta Monsta is offline
Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.
Excellent post, NoMo. This should help folks see the difference side by side.
Old 09-02-2005, 05:48 PM
PhotoJoe PhotoJoe is offline
PhotoJoe is starting off with a positive reputation.
Exlnt. I'm thinking through my options on my 2002 X right now. Probably going with the Banks. I bought my X used, already equipped with brake contrller and air bags, so I got to wondering if by chance that y pipe had been swapped out. No such luck. It is amazing how restrictive it is. Your pix are a great idea, but don't do the factory pipe the injustice it deserves. The restriction is not really visible. Any chance of a closeup of that section? If not, cool. I'm a professional photographer and when mine comes out, I'll shoot some pix. Thanks again for the side by side.
Old 09-02-2005, 05:51 PM
Sorry NoMo, I hadn't looked at the other images. It does show the restriction. Thanks.
Old 09-02-2005, 06:10 PM
captain p4's Avatar
captain p4 captain p4 is offline
captain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud of
Do they use the same restrictive y-pipe on 5.4's? 2000 f150 more specifically.
Maybe i'll have to convice my dad to upgrade the y pipe on the 01 v10 he just bough.
Old 09-02-2005, 07:03 PM
cc322's Avatar
cc322 cc322 is offline
cc322 is gaining momentum as a positive member of FTE.
Later, I'll try to post some pics of the 2005 3V factory exhaust- which is MUCH better than past designs.
Best and most informative post I have seen in a while GREAT JOB Man I want to do it can you fill the differance???
Old 09-02-2005, 07:12 PM
Cooke V10 Cooke V10 is offline
Cooke V10 is starting off with a positive reputation.
Cant wait for the 05 pics. Great post!!
Old 09-02-2005, 08:34 PM
cc322's Avatar
Great pics boy how things have changed from the earlier years
Old 09-02-2005, 09:49 PM
Im guessing the Ford Racing headers mate right up with the downpipes that go to that Y or will I have to get new pieces? Does anyone know? Im talking about the 05
Old 09-05-2005, 02:22 AM
Monsta's Avatar
Now THAT'S a Y-pipe!
Old 09-05-2005, 02:23 AM
Monsta's Avatar
Thread title updated to help others find it later...
Old 09-05-2005, 12:24 PM
NoMo's Avatar
Good idea on changing the title! As you can tell, I didn't put much thought into it.
Ken, can you also merge my posts so that the links are all in one location? Feel free to edit however you deem necessary.
Old 09-05-2005, 01:52 PM
SuperBlue's Avatar
SuperBlue SuperBlue is offline
SuperBlue is starting off with a positive reputation.
Thumbs up
Nice pics! Are those stock Y-Pipes? I have a 2006, do you know if they are the same?
Old 09-05-2005, 01:57 PM
NoMo's Avatar
That is the factory Y-pipe for '05. I suspect the '06 models to be the same, but you'll have to look under your truck to be sure. IF your Y-pipe is different, please post a pic so we'll have that version too.
6.8L V10 Excursion Full exhaust? dfoxengr Excursion - King of SUVs 27 04-01-2016 10:47 AM
y-pipe and exhaust flutter duetsch65 Modular V10 (6.8l) 92 01-28-2012 10:48 PM
Header Noise? Exhaust Leak? Flutter? 1975StroppeBaja 1999 to 2016 Super Duty 16 07-05-2010 04:47 PM
Magnaflow & 6.8L V10 1ViciousGSX Modular V10 (6.8l) 38 12-25-2009 10:51 AM
V-10 y-pipe krusterzf-350 Modular V10 (6.8l) 12 04-23-2009 09:03 AM
Tags
brake, contrller, duty, excursion, f250, ford, pictures, pipe, pipes, set, super, v10, xl, y, ypipes
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
