Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Iowa Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Iowa Chapter Join Chapter, Leader: fellro86
  #1 (permalink)
Old 09-02-2005, 01:42 PM
concretegarage's Avatar
concretegarage concretegarage is offline
Garage is empty, add now
concretegarage is starting off with a positive reputation.
Anybody know where I can find 8 bolt front hubs?
Its for my '55 F350. I'm replacing the rear axle with a Dana 70 and would like to keep the bolt pattern the same. I've heard that some of the 250's had 8 bolt wheel patterns, and was hoping to locate some hubs that I could put on the front of my truck.
  #2 (permalink)
Old 09-02-2005, 03:01 PM
fordloverf2501970's Avatar
fordloverf2501970 fordloverf2501970 is offline
fordloverf2501970 is starting off with a positive reputation.
i am sure dougs would have some down in pella, but dont know what he sells them for
__________________
Iowa chapter member
FTE supporter
If you can read this, thank a Teacher
if it is in english, Thank a Soldier !
Currently truckless and Laid Off!
but i am happy!
  #3 (permalink)
Old 09-02-2005, 03:03 PM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
1967 Ford Galaxie
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
I don't know for sure what spindles you have or if you have converted them to disk brakes but almost every junkyard in the state should have F250s around, and yes they would be 8 bolt hubs or a better bet would be to look for an E350 cube van like the D70 most likely came out of.
__________________
Rob
Learn from your parents mistakes.......... Use birth control
  #4 (permalink)
Old 09-02-2005, 07:39 PM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
1978 Ford F-150
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
I've got a front stub that has the hubs on it. I would have to go look to be absolutely certain, but I do believe I have them. All 250's have 8 bolts at least after the 60's. Trick is that you have a straight axle, and these are twin I beam.. I know that a 64 would have a straight axle with the 8 bolt hubs.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto
Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
  #5 (permalink)
Old 09-03-2005, 07:22 AM
69 and 85's Avatar
69 and 85 69 and 85 is offline
69 and 85 is starting off with a positive reputation.
Do you already have the Dana 70? I have one as well as the fronts, but again.... twin I-beam from an F350.
__________________
91 Blue F250
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
