Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 09-01-2005, 03:45 PM
77300i6's Avatar
77300i6 77300i6 is offline
Garage is empty, add now
77300i6 is starting off with a positive reputation.
Question Octane
I was wondering why don't they use higher octane fuel. Wouldn't that allow more power (from a smaller engine) and fuel efficency? It would clean up the combustion chambers leading to reduced emissions, and allow higher compression ratios.
Japan runs something like 100 octane, so why do we have 87? The highest I have seen is 94.
Anyone care to comment on this?
__________________
"The fortune you seek is in another cookie"
2004 Taurus SEL 24V DOHC; 100K (Mine)
1999 F150 XLT Scab 4x4 5.4L/Auto 3.55LS; 77K (Hers)
  #2 (permalink)
Old 09-01-2005, 03:54 PM
kingfish51 kingfish51 is offline
kingfish51 is starting off with a positive reputation.
Octane costs money. Costs more to boost it that high and the engines can be designed to run on lower octane without losing power.
  #3 (permalink)
Old 09-01-2005, 08:29 PM
ckal704's Avatar
ckal704 ckal704 is offline
ckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud of
So many people misunderstand the true meaning of "Octane Rating"........
It is simply a quantification of how difficult a fuel is to ignite. The higher the octane, the harder it is to ignite it. That is why low-octane fuel is recommended for such a great percentage of vehicles on the road; they have relatively low compression ratios and thus need lower octane fuel for it to be able to be consumed properly by the flame during the ignition process and subsequent power stroke. High compression ratio engines on the other hand, need higher octane fuel since the heat of compression would light the fuel prior to the spark occurring (pre-ignition) or the secondary compression that occurs after the spark lights the a/f mixture in the combustion chamber and the expanding burning fuel further compresses the portion not yet burning to the point that it spontaneously ignites itself elswhere in the combustion chamber (detonation). Both are deleterious to engine longevity. If you can remember when they used to advertise on TV for high octane gas there was tiny print at the bottom of the screen that said "for engines that benefit from higher octane fuels".
I can't remember the exact number, but diesel fuel is of significantly lower octane than gasoline, thus its ability to self-ignite due to the very high compression ratios common to diesel engines.
I am sure there are plenty of thread explaining this better than me elswhere in these forums, but they will affirm that high octane fuel in a 8.5:1 compression ratio engine is a complete waste of money.
__________________
Kal
97 250 PSD Ex Cab Sd 4X4 ZF5 185k
Buncha low budget mods
"I tried being reasonable. I didn't like it."
  #4 (permalink)
Old 09-02-2005, 12:05 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Moved to proper forum.
__________________
"Beam me up Scotty. There's no intelligent life down here..."
Tags
1999, 42, f150, ford, fuel, octane, proper, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
