4x4 Conversion
4x4 Conversion
Could someone give me an idea of what might be involved in converting my '67 F100 to 4x4? I know the front and rear gear ratios should match, but I don't have any clue whether a 4x4 front end/suspension/steering will bolt directly into a truck that wasn't manufactured with it. I understand there are parts to buy of course, but is it do-able without major modifications to the truck other that parts replacements?
If you are good with a torch and welder, anything is possible.
Honestly, it's cheaper and easier to start with a 4X4 chassis and build from there. There are enough differences between the two that even some of the common parts won't interchange without extra work.
It has been done, check the Offroad and 4x4 forum. Try out the search function as well.
https://www.ford-trucks.com/forums/f...splay.php?f=63
If youre looking for a donor truck...i think i have one. Lemme check, and if youre interested in it. Let me know and ill get a price on it. Hopefully the truck wouldnt cost much more than buying everything separate, and hacking it together.
The easiest way is deffinently to find a donor truck, swap your motor and body off your 2wd to the 4wd, and be done. Ofcourse theres more to it than that. But it is deffinently the easiest way.
--John
--John
EODguyJake
6.7L Power Stroke Diesel
11-10-2014 08:51 PM
tobygo67
11-06-2014 09:35 AM
minnesotafisherman
07-31-2012 07:25 PM
