!!HELP!! Brakes Pulsing (ABS)
Hi all,
My unchel has a 94 bronco with the 5.0 L. it has ABS and the brakes are pulsing really bad. We changed the rear drums, slave cylinder, springs shoes and the front pads also. After that they still pulsed but only after you depressed the pedal more than mabey 2 inches....so i checked the fuse....the ABS fuse was missing so i put the appropriate fuse in and we bled the entire system and they still pulsed. The pedal has a really good feel to it and the breaks work very well if you go on them light but if you press the pedal more then lightly they pulse.
any help i would greatly appreciate
thank you,
Gui88ford
thank you,
Gui88ford
Originally Posted by al_huryn
You do not have to turn new rotors, all you need to do is take some sand paper and use it in a swirling motion so you leave a non-directional finish on the new rotor.
ATV PRO #11
1999 to 2016 Super Duty
06-16-2020 06:33 PM
mike bell
02-05-2012 03:32 PM
bucktaylor
1997-2006 Expedition & Navigator
07-29-2009 08:58 PM
