gear swap ?'s - Page 3 - Ford Truck Enthusiasts Forums
gear swap ?'s
  #31
Old 09-26-2005, 03:23 PM
TINY G'S F150 TINY G'S F150 is offline
TINY G'S F150 is starting off with a positive reputation.
Quote:
Originally Posted by stang3O2
Thanks TinyG...I keep going back and forth between thinking 4.10s to 4.56s...sounds like everyone thinks 4.56 is the way to go!
No problem I looked at some 4:30 gears also thats right in the middle but I am tickled with my decision.. I couldnt get the 4:30 gears from Ford so thats kinda why I opted to do the 4:56's. Yukon makes a 4:30 if you go on e-bay theres plenty of them..
  #32
Old 09-26-2005, 07:30 PM
ATC Crazy's Avatar
ATC Crazy ATC Crazy is offline
ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.
These should give you some good choices to choose from. I have 32" tires and I am looking for something besides my 3.55's. I have horrible low end (I like a lot of torque).
www.ringpinion.com
www.differentials.com
www.reiderracing.com
www.drivetraindepot.com
www.ringpinion.biz
  #33
Old 09-26-2005, 10:05 PM
stang3O2 stang3O2 is offline
stang3O2 is starting off with a positive reputation.
Thanks TinyG and ATC! Im with ya ATC on the low end, 35s with a 3.55s, I think I could get a better runnin start on foot, ha! Im just really concerned with the daily driver my truck is, and running really high rpms at higher speeds. Ive tried all the formulas and calcs to try to figure my rpms with a gear change but dont think im coming up with what it will be in "reality."
  #34
Old 09-26-2005, 10:19 PM
ATC..Just checked out the web sites...very helpful, I appreciate it!
  #35
Old 09-27-2005, 12:55 PM
If you think your was bad mine had 3:05 gears with 35's I needed a 2 mile ramp to get on the highway My truck is also my daily driver and it has plenty of torque now and good highway power. I can actually get in the fast lane now I stay with traffic at around 2300 rpms so the high rpm's isnt a problem..
Fifthwheel towing with lift kit Hedgehog1 Fifth Wheel & Gooseneck RV Towing 5 09-22-2015 03:18 PM
need new ratios KAGAN21 Clutch, Transmission, Differential, Axle & Transfer Case 6 05-03-2014 12:07 AM
Lifting Independant Front Suspension??? Gear619 1987 - 1996 F150 & Larger F-Series Trucks 5 04-24-2014 10:50 AM
33's and 3.55 gears Bob Gervais 1987 - 1996 F150 & Larger F-Series Trucks 17 02-12-2009 11:32 PM
Disappointed with my V10 J--Rod 1999 to 2016 Super Duty 84 10-16-2006 12:39 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
