International wins again... - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 08-30-2005, 10:24 PM
Reptar360's Avatar
Reptar360 Reptar360 is offline
Reptar360 is starting off with a positive reputation.
Thumbs up International wins again...
Thanks to this forum, I was able to find part numbers for the Ford "vacuum switch" or "restricted fuel filter sensor" as international calls it. Mine started leaking a bit and after reading through many, many posts I found the info on this part. Thanks to everyone! These trucks can be expensive enough without Ford taking advantage of us.
Ford #E8TZ-9S283-A $58.00
International #1809435C1 $14.00
Old 08-30-2005, 10:28 PM
DR JOE DR JOE is offline
DR JOE is starting off with a positive reputation.
What does it do??? And where is it??
Old 08-30-2005, 10:45 PM
WA.Ranger's Avatar
WA.Ranger WA.Ranger is offline
WA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to all
yeah, what does it do?
Old 08-30-2005, 11:12 PM
Reptar360's Avatar
Fuel Filter Restricted sensor; on filter housing 94/95; on regulator block 96/97
(Ford) E8TZ-9S283-A
This is the sensor that triggers the "fuel filter" warning light on the dash. Looks like an old fashioned oil pressure sending unit with a single red with white stripe wire attached to the top. On my 97 it is located on the right side of the fuel filter on the fuel pressure regulator block.
Old 08-30-2005, 11:20 PM
Thanks for the info... Do they have them on the 2001 PSD??
WA.Ranger's Avatar
Ahhhhh..thank you for clarifying
1978 460 external to internal regulated alternator question three.on.the.tree 1973 - 1979 F-100 & Larger F-Series Trucks 8 02-07-2016 11:24 PM
Clutch External slave to Internal slave conversion aikensj 1987 - 1996 F150 & Larger F-Series Trucks 11 08-09-2015 02:37 PM
INTERNATIONAL head gasket part number maxtruck00 6.0L Power Stroke Diesel 8 06-09-2014 10:29 PM
Injector part number for international Nj shade 1999 - 2003 7.3L Power Stroke Diesel 17 04-17-2014 07:04 PM
7.2L engine in a FORD? Daz00Excursion S. California Chapter 3 04-17-2014 05:38 PM
Tags
1809435c1, 73, 9s283, e8tz, e8tz9s283a, filter, ford, fuel, part, powerstroke, restriced, restricted, sensor, switch, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
