Mystery Wheel Cylinder
My '50 F-3, fresh from the farmer's field has original 8-bolt wheels on the back and 5 x 5.5 bolt 16" wheels on the front. While working through the brake system last night, I finally got to looking at the front wheel cylinders. The front wheels are old, and obviously came from something else, but I wasn't prepared to find a wheel cylinder with a 1-3/8" bore on one end and a 1" bore on the other. It's got kind of a cone shaped spring in it to accomodate the body. The body bore changes diameter at the center in one step. Oddly, it's machined to be held in place by three 1/2" bolts (as opposed to the far more common "three bolts remaining, one broken off in hole" option elsewhere on the truck ). I've never seen such a wheel cylinder. NAPA can't identify the thing. I could post a picture here if that's helpful, but can anyone tell what this is from? Old Dodge or International?
Yes, those wheel cyls are stock for that truck. Part number is 21A 2061 for left, 21A 2062 for right. Take these numbers to NAPA or CarQuest and they can enter it into the computer to cross over to thier numbers. If not, try JobLot auto in Queens, NY and Bob Selzam in N.J to name a couple. There's a place in Washington state that has them.
Collectors auto supply, Oroville, WA. 1-800-414-4462
They list 22 of each number in stock.
Barry
50 F-1
Barry
50 F-1
Thanks Chris...
These wheel cylinders are definetly not "stock" on a '50 F-3. However, I went to studying a book with a Ford hero at NAPA and we sorted out that they fit '42 - '48 half-ton trucks. Crazy looking things with the two different sized bores...Anyway, someone in the past put these five bolt wheels up front on the F-3 either to give the truck a raked look or got halfway through a conversion to 5-bolts all around, or who knows...55 years is a long time to do some weird stuff as I'm sure you've found in yours...
Thanks as always!
Thanks as always!
I bet they had a hard time finding the F3 brake parts so they put the F1 parts on the front they are cheaper and easier to find. I am willing to bet all the front pieces are F1. The spindles are exactly the same for an F1 and an F3.
Originally Posted by 2bocat
Thanks Chris...
Thanks as always!
Thanks as always!
make tank move
Goal at moment is to make the thing moveable under its own power. It's rather stuck in the shop at the moment. To that end, I repaired fuel pump and got motor running (still needs carb kit and pass. side water pump work), cleaned out the gas tank (a great example of working harder not smarter...geez), honed/kitted the rear brakes and will finish honing/rebuilding the front brakes shortly. I gotta finish my '66 before I start anything else!...but at least I'll be able to get the '50 in and out of the way when I need to. Ultimately, I'll replace the rear axle with a newer 9-inch, 5 x 5.5 axle so I can actually repair the brakes properly. I think it'd be a hoot to drive this tank to work occasionally! ...tell you what, you've got to be a man's man to monkey with those huge heavy original brakes/drums/axles on the back of the F-3s. BTW - do you have any idea why Ford put the three countersunk screws in the original rear drums that hold them to the axle? What with 8 big lugs to do the same thing, I can't figure out the purpose of these three little screws...
I wondered about the value of those screws myself. The slots in mine were very spread open. I used a square shank screw driver and turned them with a 12" crescent wrench to get them off. I replaced them with stainless steel allen-drive flathead screws. I could see having one just to hold the drums in place on the assembly line until the wheels are in place, but three is a mystery; maybe they were worried about balance if they just used one.
I've toyed with the idea of a 9" Ford rear end, but I would stay with 8 lugs.
Ya...I had to bash mine with a punch to get them started before I could use a regular screwdriver to finish removing them. Wheel bearings looked kinda odd when I took the front drums off last night. Upon closer inspection, the inner bearings don't seat against the back of the spindles. I tapped the first one with a punch to try to get it off the spindle and it fell into two pieces!....glad I didn't "get" to drive the thing before I took a good look around. Amazing... Anyway...guess I get to spend some more money for bearings now, oh and a rubber brake line, and a carb rebuild kit, and a water pump, and some antifreeze, and...geez I'm going broke on my "quick" fix-up program.
I don't know what your experience has been, but whoever originally sorted out the design for the master cylinder on these trucks should have been summarily executed. Got that dang thing installed too last night in a hail of profanity bad enough to make the dog leave the shop...
Meant to mention I really love the paint on your '52...nice job.
They really tucked away that master cylinder. I've contemplated getting a modern two resevoir, possibly power brake, master cylinder. It would be easier if that cab were not in the way.
Thanks for the compliment on the paint; I just got the front sheet metal and painted and reassembled this spring.
