35s tore up a rearend!
My roommate has a 98 F-150 2wd (4.2 V6) which he lifted with 35's about 7 months ago. He regeared to 4.88s about 3 months ago. A couple of days ago his rearend let go and grenaded everything inside the diff. Now for the questions...First of all, what's the stock rearend under these trucks? Secondly, what's a good rearend to swap under there if the stock one is prone to breakage? I figured a Dana 60 would handle pretty much anything you throw at it, but maybe something smaller would work too? How involved is the swap? Any answers would be greatly appreciated.
Who did the rear end work? Any possiblity is was not done right? Was there any wining or grinding or did it just let go all of a sudden?
If the rear end alignment was off it would do that. In other words, when you lift a truck, the transmission and rear end need to have the correct angle of the dangle between them. The u joints have to have the same amount of swivel, or one end or the other will vibrate. I've never heard of blowing a diff because of bigger tires. Not like that 4.2 was abusing it with too much power either.
Harmosm
04-18-2008 08:27 AM
Kamikazee
04-19-2002 06:38 PM
