My Truck Will Not Idle At Times.sometimes It Runs And Will Idle Just Fine.then It Will Take Anotion Not To.i Have Adjusted Idle Screw .the Truck Runs Fine Otherwise.any Suggestions?
Have you changed the PCV valve? They can do some strange stuff. Have you changed the fuel filters? When it won't idle, does it run ok at other than idle?
