You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
they got these going on on the 18th. think i might enter they have a 4wd class .rob do you think the bfg all terrains and with my motor set up it might be worth entering,, running 35"s and 3.73". not sure what class i would be in .
__________________
so many chevies, so little time
check all the rules before you get too carried away. I couldn't compete with my truck unless I undid some things, and had to have a different bumper, so I didn't bother. You may get put into a class that is too much for you by some simple mods you have, so it may end up the same way as I was...
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
what were some of the things you had to do and what was wrong with your bumper .i have one of those steel diamond plated step bumpers .like i said not sure about class specs but will maybe see if i can find a flyer and call someone.anyone from around dewitt seen any of the flyers ?
__________________
I have an ag hitch bumper, it has to be solid, mine has give for cushion. I also have an electric fuel pump on my diesel, so that wasn't allowed. There was a couple other things that I don't recall now. If you can get ahold of whoever is officiating the pull they should be able to give you the rules. The local pull had theirs listed online.
__________________
