Increasing the performance and gas mileage of my F-150 - Page 2 - Ford Truck Enthusiasts Forums
Old 09-05-2005, 10:16 AM
lariat97's Avatar
lariat97 lariat97 is offline
lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.
My best mpg mod was efans. I gained about 2 mpg with them. I have several other mods like a superchip,K&N & dual exhaust but I didn't notice much mileage gain from them.
Old 09-05-2005, 11:16 AM
code_red's Avatar
code_red code_red is offline
code_red is starting off with a positive reputation.
Lariat , you wouldnt happen to have the model number/brand name for those electronic fans you have would ya? I was thinking about trying them out in the future.
Old 09-05-2005, 10:04 PM
RoyalFord RoyalFord is offline
RoyalFord is starting off with a positive reputation.
Yes, I am looking for electric fan kit too.
But, I don't want a manual kit (to turn off/on). I want one that will turn on when the stock mechanical clutch would kick in based on temp so it doesn't run all the time.
I have heard the electric fan is the best thing that help MPG from many people.
Old 09-07-2005, 12:12 PM
78 short 78 short is offline
78 short is starting off with a positive reputation.
I was told by ford tech that you shouldn't use any injector cleaner in these new tritan engines.All of them.The injectors have a factory coating on them that stops buildup.Once you use a cleaner through them, it takes off that coating and then you'll be cleaning the dam things every other month.I see alot of peaple on rthis site reconmending this procedure..I hope I'm wrong or lots of peaple just recked there injectors.
Old 09-07-2005, 05:35 PM
code_red's Avatar
Ive heard about the throttle body housing having a protective coating on it, but this is a 1st on the actual injectors themselfs??????? Anyone?
Old 09-07-2005, 09:44 PM
lariat97's Avatar
I would post my efan model but the site edits the brand. they works off your engine temp. It has 2- 16 inch severe duty electric fans with 225 watt motors & seperate controllers for each. They come with everything to install them & great instructions. You will need a temp probe to set the controllers. I've been running them for 2 yrs & no problems. Pm me if you want the brand name & where to get them.
Old 09-08-2005, 06:08 AM
I'll double check with that ford tech to see if I misunderstood him or something....I'll get back to that.
Old 09-14-2005, 12:50 PM
murph1's Avatar
murph1 murph1 is offline
murph1 is starting off with a positive reputation.
Talking
something that i have just done to increase mileage that was not brought up was to make sure your brakes are no dragging..just did a complete brake job and you would not believe how much effort it had taken to loose the pads..the slides had rust under them and the sleeved slides would not budge..appox. 50k and its a 99 150 4x4 with discs..in the several days time since finishing i gained 2mpg city...for me thats several tanks of gas per year=money in my pocket..there are not many so called "bolt ons" that will give you that in writing/money back gaurantee..even if you just did brakes 15k ago check out them brakes...its your money..i hope to take a short trip this weekend and i hope to see 3mpg gains on the highway...don't forget the emergancy brake also if you have discs..
ok i got a few ????s powerstrokeddiesel 1994.5 - 1997 7.3L Power Stroke Diesel 38 02-08-2008 07:31 AM
Wtf? nlfireblade 2004 - 2008 F150 15 11-01-2007 04:36 PM
performance resistor TxFordGuy Ranger & B-Series 4 04-18-2007 04:59 AM
Gain 110 HP , 220 Ft/ Lb.s for under $400???? BS or real? SPL Tech Excursion - King of SUVs 27 01-08-2007 10:19 PM
This must be real heavy Noble Lumpkin Ranger & B-Series 26 03-23-2006 08:53 PM
Tags
150, 2001, 2003, 94, air, f150, filter, fuel, gas, increase, increasing, mileage, perfomance
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
