What is the largest filter I can use? - Ford Truck Enthusiasts Forums
Oil & Lubrication NO MLM Dealers, Wholesale Buyers Or Retailers allowed (except sponsors)
SPONSORED BY:
Old 08-29-2005, 07:55 AM
Golfmore Golfmore is offline
Golfmore is starting off with a positive reputation.
In a FL1A application? I want to put a larger filter in my 92 XL all manual. Thanks.
Old 08-29-2005, 11:30 PM
TallPaul's Avatar
TallPaul TallPaul is offline
TallPaul is gaining momentum as a positive member of FTE.
The best bet is to run a FL299 which is 1.5 inches longer and the same in all other respects, but probably a thicker can since it is longer. But the FL299 is expensive at the dealer. I order the Purolator version (L40017) for $6 at Advance Auto and they have it the next day. This particular Purolator has the Motorcraft-style threaded end bypass valve too.
Old 08-30-2005, 01:28 AM
Big O Dave's Avatar
Big O Dave Big O Dave is offline
Big O Dave is starting off with a positive reputation.
TallPaul is right! Here's a list of larger filters, including the FL-299. I've cut open "virgin" filters and measured the surface area of the filter element. TP did the same with the Purolator, which I don't have on my list... perhaps he'll post it, as well.
Here's the list:
Code:
                        Pleat     #           Element      Surface
                        Depth    Pleats       Width        Area
Motorcraft	FL-299	0.750	   64	      5.50	   528.00
Fram	        PH977A	0.656	   56	      5.69	   418.03
Baldwin         BT251	0.750	   51	      5.38	   411.19
Donaldson	P550299	0.625	   60	      5.00	   375.00
Wix             51773	0.688	   49	      5.13	   345.30
For Comparison (standard OEM size):
Motorcraft      FL-1A   0.719      56         3.75         301.88
The thing to remember is that surface area is not all there is to the filtering ability of a filter... the element material is at least as important (if not more).
Old 08-30-2005, 03:25 AM
Thanks for the help.
Old 08-30-2005, 03:30 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
at kragen you can get 2 purolater filters for 5.00 on sale. they had the l40017 in stock and sold me them both for 5.00.
Old 08-30-2005, 08:10 AM
TallPaul's Avatar
Thanks for posting your list Big O Dave. I tried to link to the Oil Guy site and it would not work. Here is my Purolator L40017 data (used filter vs Big O Dave's were new) next to Dave's FL-299 data:
Code:
Filter	Pleat  #Pleats  Element  Element
 	Depth           Width    Area
L40017	0.719	66	5.38	511.00
BTW, someone at this site a couple years ago posted that the longer FL299 was spec for IIRC an '89 F850 with 460 V8 (among many other years and models obviously).
I use the L40017 on my motorhome and sometimes on my 300 I6. Not to leave the very good FL1A behind, I am running that on the Aerostar 3.0, which specs a FL400.
Last edited by TallPaul; 08-30-2005 at 08:16 AM. Reason: Add brand name and other info
Old 09-10-2005, 12:18 PM
Big O Dave's Avatar
Smile
*bump*
Old 09-10-2005, 04:47 PM
Thanks guys for the help. I was considering the filter area, and possibly a little more cooling?
Old 09-18-2005, 04:50 PM
boxcar_tommie22 boxcar_tommie22 is offline
boxcar_tommie22 is starting off with a positive reputation.
i my ford calls for motorcrat fl820s...i use a much larger size 5.6 in long compared to fl820s 4 incs...fleetguards lf3315 and baldwin b281...
Filter change brother steve 6.7L Power Stroke Diesel 15 10-29-2015 03:24 PM
Cabin Air Filter? fordtruck661 1999 - 2003 7.3L Power Stroke Diesel 4 10-22-2011 09:44 PM
Ceramic fuel filter john fin 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 03-05-2011 04:59 PM
Two fuel filters? Scratcher Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 06-08-2010 10:50 AM
Where is the External Transmission oil Filter? jobguy 6.0L Power Stroke Diesel 4 09-17-2004 09:36 AM
Tags
299, 51773, f850, filter, fl, fl1a, fl299, ford, fram, kragen, motorcraft, oil, ph977a, spec, thread, wix
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
