Pictures of oil relief valve in filter housing. - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 12-03-2009, 10:37 PM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
Old threads never die.
  #47
Old 12-04-2009, 12:22 AM
clem1226's Avatar
clem1226 clem1226 is online now
clem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to behold
Quote:
just like old 7.3s ....can I get a wittness?
  #48
Old 12-04-2009, 04:25 AM
WA.Ranger's Avatar
WA.Ranger WA.Ranger is offline
WA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to all
Quote:
AMEN Brother!
  #49
Old 12-20-2010, 07:02 AM
mq1shooter's Avatar
mq1shooter mq1shooter is offline
mq1shooter is starting off with a positive reputation.
Wow...with 1200 more mile to go until my next Oil/Filter R&R...I'll be checking this out from now on!....It's the little things in life.....
  #50
Old 01-17-2011, 01:04 AM
onebadpsd onebadpsd is offline
onebadpsd is starting off with a positive reputation.
lookin fer a fix to this guys,id say its a helluva prob,ive seen it on almost every obs and nbs that comes threw the shop....i hate chargin 200 plus fer a new filter head...i would much rather find a "wing it" method that will be just as god and cheap fer the customer
  #51
Old 01-17-2011, 10:06 AM
WA.Ranger's Avatar
Checking in for the 2011 post!
  #52
Old 01-17-2011, 03:40 PM
cavitation cavitation is offline
cavitation is gaining momentum as a positive member of FTE.
Gotta love vintage threads. Appreciated by those of us with a sense of history.
  #53
Old 02-21-2011, 07:25 PM
harris2108 harris2108 is offline
harris2108 is starting off with a positive reputation.
Just ran into this problem on my Dads '95, Oil cooler oring leaking oil. Removed cooler to install new core and orings. While cleaning up the parts I noticed the by-pass valve was missing. The oil pressure regulator valve was also loose in its bore and fell out during removal. Gonna bite the bullet and get a new filter head from Ford, $152
If you don't want a coolant bath there is a plug in the block that will drain most of the coolant out of oil cooler and block. On this truck, it was to the rear of the filter head and required a 1/4" sq driver to remove. I loosened it until the coolant would dribble out into a bucket. Took about 10 minutes but my sleeves stayed dry.
  #54
Old 02-21-2011, 07:47 PM
01EX 01EX is offline
01EX is gaining momentum as a positive member of FTE.
great thread
  #55
Old 08-26-2014, 09:57 PM
Sketer Sketer is offline
Sketer is starting off with a positive reputation.
Interesting thread for sure.
My gal has a 1996 350 with the 7.3 v8 rattle.
It is fun leaving and entering a quiet RV park.
My gal, who likes getting all oily, figured she
would change the oil and filter. I was working
on the other side of the shop when I heard an
unusual screech. She had dropped the filter on
her chest because a spring had hit her in the
face, O'well. There was oil every where. Looked
for the spring and found the plastic plug and the
washer, took a while to find the spring.It had fell
in that extra garment under her shirt, go figure.
I got under the truck and found where the parts
had come from (after reading here). Funny thing
is there was nothing holding it all in place except
three peen marks. There is no groove for a snap
ring or pin of any kind. Called a friend who said he
had seen this once before. Without going to buy
another filter adapter, I just did a better job of
peening it back in place on the edge with a sharp
pointed punch. Find out if it held in about 3000
miles.
I should have taken some photos of the project.
fuel heater fix directions!!!!! w/pics rupejosh Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 86 01-27-2017 08:07 PM
Added some More spikes...Pics! dvldog458 Excursion - King of SUVs 57 06-04-2015 11:48 AM
My new tires 315x70x17 Sanddriver 1997-2006 Expedition & Navigator 19 10-30-2013 12:52 AM
picture test harrisford User Gallery & Picture Display 3 07-16-2011 09:09 PM
Possible Crewcab F250 2WD for sale Roller150 1973 - 1979 F-100 & Larger F-Series Trucks 3 01-04-2011 08:13 AM
Tags
1996, 73, filter, ford, housing, jetta, location, lpop, oil, pictures, pressure, relief, replacing, valve, vw
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
