Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #31 (permalink)
Old 04-23-2007, 07:00 PM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Jesus spoke a lot
1999 Ford F-550
Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future
Quote:
Originally Posted by The Grinch
Kwik, I am repairing a leaking oil cooler. I have the ends free but am unable to pull the cooler out due to clearance with the engine/frame. How can I lift the engine without lifting from the oil pan? A bottle jack on the engine mount? Plus 3 parts came out of the rear/oil filter housing. The spring I see above and 2 hollw cylinders, one fits into the other. How does it all go back together because I don't think they were supposed to come out.
I would use (rent one if you don't have one) a cherry picker and lift it from above. It's the only safe way to do it.
An alternative is get a come-along and attach it to an overhead beam capable of holding the weight, remove the hood and lift it that way.
That beam would need to be stout. 2x4 roof joists need not apply.
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, all stock.
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
God and Dog
  #32 (permalink)
Old 04-24-2007, 02:20 PM
The Grinch The Grinch is offline
The Grinch is starting off with a positive reputation.
Kwik, is there a good place to hook up to on the left side of the motor? I am only lifting the left side enough, a couple of inches, to pull out the oil cooler and end caps.
__________________
95 F250 HD PSD SC LB 4X4 5 spd 4.10 Original Owner 134k miles 3 in. dwnpipe Isspro EGT & Boost Gages Pre-Luber K&N Rhino Lining Clifford Alrm Snugtop Expo Cap PowerStroke Registry Member
  #33 (permalink)
Old 04-25-2007, 05:57 AM
Jesus spoke a lot
1999 Ford F-550
Isn't there a lifting stirrup on the left front? I know for sure there is on the RR because I took mine off and stored it.
__________________
Dan
God and Dog
  #34 (permalink)
Old 04-25-2007, 10:34 AM
I'll check, but the only one I have seen is on the right side. I have enough info now to make it work. I just need to figure out the 3 pices that came out of the gasket side of the rear oil cooler mount. The 2 hollow cylinders, on fits inside the other, and the spring. Any ideas on this? Thanks!
__________________
  #35 (permalink)
Old 04-25-2007, 10:59 AM
BobbyDiesel71's Avatar
BobbyDiesel71 BobbyDiesel71 is offline
IL chapter LDR
2002 Ford F-350
BobbyDiesel71 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Kwikkordead
Yeah, get the parts necessary and a good circlip tool. I used a 3/8" socket extension to hold the assembly in place while I worked the circlip up into it's groove. The male part of the extension fits perfectly into the hole and the shoulder pushes on the washer. It all wants to jump apart with the spring pressure until you get it securely pushed up into the hole where you can install the circlip. Don't force it you'll break the wafer against the guide ribs in the inside if misaligned. That was the PITA, it kept wanting to go sideways and several times it jumped out on me and I had to go fishing for it across the shop floor.
what is the reason for this fix?
just curious
__________________
DP TUNED
swamps single shots
02 F-350 lariat srw,longbed 4x4
Transgo Tugger II, TRU-COOL 4739, AFE stage II intake, Bully Dog 5" turbo back exhaust
  #36 (permalink)
Old 04-25-2007, 03:09 PM
kawika's Avatar
kawika kawika is offline
kawika is gaining momentum as a positive member of FTE.
Quote:
just curious
Bob,
Sometimes the oil relief valve pops out of the hole and without it you are using unfiltered oil thru your motor. You are wanting to make sure the oil relief valve is in every time you change your filter.
So when you take out your filter and see some parts, do not throw them away.
__________________
01 F250 7.3 PSD CC 4x4 Lariat Auto
Skyjacker 6" lift, 37in BFG KO
BTS Trans w/6.0 cooler
K&N FIPK w/Filter Wrap
hpx mod, 3 Gauge A-Pillar, DP Tuner
4in Exhaust Turbo back
"Gray" CPS, AIH delete
  #37 (permalink)
Old 04-25-2007, 06:39 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie PowerstrokeJunkie is offline
2002 Ford F-350
PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold
you do not need to pull the engine to remove and replace the oil cooler. I did before on a job i was doing. Remove the oil filter, drain the crankcase oil, and leave the plug out. Remove two bolts holding the front header, and three on the rear. Then seperate the gaskets, and pull the oil cooler backwards, and down at the rear first. Lots of coolant will come out of the cooler when you seperate the gaskets, so be prepared for a shower, and you will even get some in the oil pan, the port that the oil outlet returns to the sump. Let the plug out and then it will all drain out. Also when you tilt the cooler, oil and water will come out and fall everywhere. Keep your mouth closed (don't ask). It isn't hard to do, i thought. If you have a stock style water pump, removing the lower hose and the inlet neck will make the front bolts alot easier to get to.
__________________
2002 F-350 with some mods, current best 12.8 @ 104 Fuel only
Spooled, Fueled, and Tuned by Swamps Diesel Performance, Trans by BTS, Engine built by me
Swamps gives me enough power to break a BTS
  #38 (permalink)
Old 04-26-2007, 08:16 AM
Question
I have done all that. Yes, pulling the cooler off was a messy job. Oil and Coolant everywhere, lots of shop rags and stains on the driveway that will last for years! My problem is I can't separate the cooler into pieces on the truck. It will have to be removed as a unit to pull apart later. Too much rust on the cooler to make an easy separation. But I don't have enough room to just pull the cooler out without lifting the engine a small bit. The other problem was the 3 parts that I found that popped out of the flat side of the oil filter end of the rear oil cooler mount. 2 hollow cylinders and one large spring that looks like the spring in the relief valve pic. How do they go back into the engine side of the filter mount. Don 't want to obstruck the oil flow by putting them back wrong.
__________________
  #39 (permalink)
Old 04-26-2007, 06:45 PM
WA.Ranger's Avatar
WA.Ranger WA.Ranger is offline
Clydes' a ^^^^^
WA.Ranger has a good reputation on FTE. WA.Ranger has a good reputation on FTE.
Costco sells some stuff called "oil eater" that will take every stitch of oil out of your driveway; at least it did mine when I dropped the filter one time.
__________________
http://i17.photobucket.com/albums/b93/JeffC05/th_huntingjacksonmeadow007.jpgJeff
01' CC PSD LARIAT 4X4 6" Spring Superlift, 37's
Proud Member Of The Brotherhood
WW,RRP AIH delete,RRP HRX, DPTuner, ISSPRO EV2's, TCT Tranny, HH mods, DFA RR and CCK, CCV, Tymar w Pete's Cover, DB 200A, 6.0 Intercooler, AD in #8, 5" Cannon, RedHead SG,
  #40 (permalink)
Old 02-25-2009, 02:38 PM
kawa's Avatar
kawa kawa is offline
kawa has a good reputation on FTE. kawa has a good reputation on FTE.
If the relief valve port in the filter assembly is UN-damaged then I would think that a "Wafer" could be made from a thin, sturdy piece of material such as plastic, phenolic, etc as long as it is impervious to oils.
It is a necessary part of the oil system and if push comes to shove then the replacement of the entire filter housing assembly is your next step.
This thread sure makes one wonder how many other defective oil relief valves may be out there as I for one have never even looked nor did I know that it was even there. I will check mine at the next oil change.
Rog
__________________
1997 Red 4X2 CC S/B-3" DP- No Kitty-6637
Cooling Sys. Filter-7 Gauges-6 Pos.PHP Chip
140V IDM-The "Cure"-CCV Mod w/Filter
1.0 Turbo-No EBP-Detroit Locker/Finned Cover
U. S. Gear Exhaust Brake-Ext. plug for Heater &
Cadillac Battery Water-On board Batt. Charger
  #41 (permalink)
Old 02-25-2009, 02:56 PM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
1999 Ford F-250
superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold
Dredging up old dead posts again Rog?
__________________
Chase
1999 F250 PSD CC SB 4x4 - his
2000 Explorer XLT 4x4 - hers
PAA Member #2
God speed Markadeck, you will be missed
ThumperTalk / All Things Moto! / SnoWest / SAWS / BRC
Tags
1996 , 73 , filter , ford , housing , jetta , location , lpop , oil , pictures , pressure , relief , replacing , valve , vw
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
