Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 03-24-2007, 09:42 AM
shunt shunt is offline
shunt is starting off with a positive reputation.
Greetings from England
Great pics of something which has been suggested on another forum as the possible cause of problems I'm having. My truck shows no pressure at idle on the gauge when it's warm, causing the HPOP to gradually drop and the motor to die. Otherwise, no other symptoms. I don't get it though. Surely if the valve was missing, oil would bypass the filter and reach the rest of the engine and the HPOP res more easily, albeit unfiltered. The oil and filter are new, by the way. Any comments to confirm or alternative suggestions before I drop another batch of expensive lubricant out of the motor?
  #17 (permalink)
Old 03-24-2007, 09:58 AM
amiller93's Avatar
amiller93 amiller93 is offline
amiller93 has a good reputation on FTE. amiller93 has a good reputation on FTE.
You need to check pressure in the low pressure oil system, if it is dropping like is sounds to be with the HPOP starving you will most likely need a new LPOP.
  #18 (permalink)
Old 03-24-2007, 11:15 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Jesus spoke a lot
1999 Ford F-550
Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future
Quote:
WOW, old thread.
I agree with what Amiller said. There's several stories of worn out LPOP causing problems.
The other thing that sticks in my mind is the possibility that one or more of the piston cooling jets have come off inside the oil pan and a lot of oil pressure is bleeding off there.
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, all stock.
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
God and Dog
  #19 (permalink)
Old 03-24-2007, 11:51 AM
Yeah, sorry it's such an old thread. Found the forum by searching for the problem and this is what the search engine threw up. It sounds like I'm in for big money! Craning an engine out and back in over here is £1,000+ (about $2000), without any other work. Just finding someone prepared to take it on is hard enough. There is no dealer support and no spares over here, so I'm clutching at any straw to avoid pulling the motor.
  #20 (permalink)
Old 03-24-2007, 12:27 PM
Jesus spoke a lot
1999 Ford F-550
That's a lot of money!
Are you in Great Britain somewhere?
__________________
Dan
God and Dog
  #21 (permalink)
Old 03-24-2007, 01:18 PM
Yep, Hertford, the place Hartford Conn. was named after. It's founder lived here.
Tiny Streets, 600 year old houses. You can imagine how rare a truck the size of an F250 longbed is!
  #22 (permalink)
Old 03-24-2007, 02:13 PM
WA.Ranger's Avatar
WA.Ranger WA.Ranger is offline
Clydes' a ^^^^^
WA.Ranger has a good reputation on FTE. WA.Ranger has a good reputation on FTE.
Very cool, not only do we get great info on the site, we get a free history lesson too. How did you come to get an F-250 over there? I wouldn't think it was a common item?
__________________
http://i17.photobucket.com/albums/b93/JeffC05/th_huntingjacksonmeadow007.jpgJeff
01' CC PSD LARIAT 4X4 6" Spring Superlift, 37's
Proud Member Of The Brotherhood
WW,RRP AIH delete,RRP HRX, DPTuner, ISSPRO EV2's, TCT Tranny, HH mods, DFA RR and CCK, CCV, Tymar w Pete's Cover, DB 200A, 6.0 Intercooler, AD in #8, 5" Cannon, RedHead SG,
  #23 (permalink)
Old 03-24-2007, 03:32 PM
Quote:
Rare as hens teeth. Part of the reason being that US vehicles don't conform to safety standards anywhere else but the US, without modification and fuel is $12 per gallon. This one was shipped from Texas in the middle of Katrina. It's been sulking ever since.
  #24 (permalink)
Old 03-24-2007, 03:45 PM
amiller93's Avatar
The LPOP is about 70 bucks here and is not that hard of a job.....no motor pulling needed. Several of our sponsors sell them and shipping would probably be cheaper than getting it across the pond.
PM me your email and I'll send you a pdf of the procedure.
  #25 (permalink)
Old 03-24-2007, 04:29 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie PowerstrokeJunkie is offline
2002 Ford F-350
PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold
Dan, today i was starting to remove the oil pan on our 95 powerstroke, and the bypass is gone, it looks just like the second picture with the open hole. Will it hurt it to run like this, or could i just get the seperate parts?
__________________
2002 F-350 with some mods, current best 12.8 @ 104 Fuel only
Spooled, Fueled, and Tuned by Swamps Diesel Performance, Trans by BTS, Engine built by me
Swamps gives me enough power to break a BTS
  #26 (permalink)
Old 03-25-2007, 06:09 AM
Thanks to amiller93 I now have a pdf in front of me which, I think, makes sense of it all. Running without the valve will reduce both the effectiveness of filtering and oil pressure, as it returns oil to the sump. This will leave the other curcuit from the LPOP, feeding to the HPOP reservoir, at a lower pressure as most of the volume of oil from the LPOP will take the easier route back via the filter housing. I would say that running without the valve is not advisable. I shall be checking mine, before resorting to replacing the LPOP.
  #27 (permalink)
Old 03-25-2007, 11:30 AM
Jesus spoke a lot
1999 Ford F-550
Quote:
In theory, it shouldn't hurt the engine - that much.
I've worked on VW air cooled engines that have for a filter a simple course screen and they go for 200,000 miles before they get opened up. The apperance of the bearings is sort of speckled, and all were worn down to the copper. The flip side to that is the later style Porche engines with the oil filter and 200,000 miles were worn down to the copper as well, but the bearings were smoother looking.
So to answer your question, I don't really know if it will truly shorten the life of your engine.
However, considering that the injectors have some pretty small passages with the potential of getting clogged with unfiltered debris, I would be more worried about them having to swallow unfiltered oil than the crankshaft.
Bottom line: you need to get that fixed, it's much better all around. You may have to buy the whole flange assembly to obtain the parts, or to just eliminate the reason that the c-clip fell out of it's place. I suspect that the little groove where it was seated is no longer there. C-clips DO NOT come out on thier own. Some outside force or failure is always the cause.
There are two bypass valves for the oiling system. One is pressure control and yes that one dumps back into the sump and is mounted in the oil pump itself.
The other one in the filter flange, to the best of my knowledge, simply routes around the filter and dumps into the passage that continues on to the engine: bearing, HPOP, etc. None of that oil gets returned to the sump until it has passed through some engine component. Your oil pressure concernes are not caused by this.
__________________
Dan
God and Dog
  #28 (permalink)
Old 03-25-2007, 11:34 AM
Jesus spoke a lot
1999 Ford F-550
Need to correct a small detail.
The oil pressure regulator, in most cases, does not vent directly back to the sump, but simply opens to a port in the oil pickup passage where it is recirculated back into the oil pump. The excess oil simply goes around in a circle within the oil pump.
__________________
Dan
God and Dog
  #29 (permalink)
Old 03-26-2007, 04:51 AM
Hmmm, it looks like I'm no futher on. Trial and error method of diagnosis ahead. I so hate that.
  #30 (permalink)
Old 04-23-2007, 04:34 PM
The Grinch The Grinch is offline
The Grinch is starting off with a positive reputation.
Oil cooler
Kwik, I am repairing a leaking oil cooler. I have the ends free but am unable to pull the cooler out due to clearance with the engine/frame. How can I lift the engine without lifting from the oil pan? A bottle jack on the engine mount? Plus 3 parts came out of the rear/oil filter housing. The spring I see above and 2 hollw cylinders, one fits into the other. How does it all go back together because I don't think they were supposed to come out.
__________________
95 F250 HD PSD SC LB 4X4 5 spd 4.10 Original Owner 134k miles 3 in. dwnpipe Isspro EGT & Boost Gages Pre-Luber K&N Rhino Lining Clifford Alrm Snugtop Expo Cap PowerStroke Registry Member
Tags
1996 , 73 , filter , ford , housing , jetta , location , lpop , oil , pictures , pressure , relief , replacing , valve , vw
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
