no hyd clutch.
no hyd clutch.
I have a 90 f-150 and cannot get the clutch to disengage. I replace the hose and the master cylinder. If you disconnect the fitting on the tranny the pedal stops dead, however it will not push the clutch enough to disengage the truck. I got the hose from ford and the master cylinder from autozone. Should I try a ford master cylinder or can you get a higher flowing master cylinder. Also what is the best way to bleed out the clutch, from what I can the clutch does have all the air bled out.
hayden01
18
08-06-2014 09:01 PM
Marteney
01-05-2014 01:33 PM
BW353
29
12-27-2012 09:10 AM
hayden01
02-06-2010 04:51 AM
