2000 van missing rear A/C control and electric sofa control
After looking in my user manual about my 2000 Jayco conversion it talks about a rear A/C fan control located overhead somewhere near the rear sofa. If mine had it, Jayco must have removed it. The driver's rear A/C fan control has a setting for the rear controls to operate the fan. Where approximately is that overhead control? I'd like to pull out the wiring and reconnect a control to it.
Also, the manual shows a control for the sofa just behind the side doors. I don't have that either. If it's there I'd like to add the control. Trying to use the control located behind the rear seat sux when your not coming thru the back doors.
The rear controls for heat/ac in my 99 are in the roof about the middle where the seats are mounted behind the driver and passenger. Now conversion vans have modified roof layouts, so the factory sitch would most likely be relocated from the roof, I'd say it's on the drivers side wall panel right beside the mid van passenger seat, right below the window.
I thought the rear bed/bench control was on the wall in the rear, passenger side, but may be on the other. Sorry, only location I know of.
I have a 96 MarkIII, and the rear fan switch is mounnted on the dash below the front fan switch. My owner's manual state's that although there is a separate heater core, the rear ac ducting robs the front system for cool air. I imagine all conversion vans, and factory rear air, are differant.
Rear AC has an evaporator in the rear for cool air, there is a T in the coolant line, sharing with the front, I don't see it as taking from the front, my ext van gets down right frigid, makes you have to cut the fans off. If the front fan switch has a setting for rear control, you have/had it, no seats are mid van in mine, so I never use the feature.
I may just add that one. It shouldn't be too hard to run wires off of the one in the back. I already have the switch.
the fan switch up front, if it has a setting for rear control, it has the connection in the line, I'd guess it goes up the wall behind the drivers seat to make it's way into the headliner. Wish I had a pic of where mine is, but when they removed the factory headliner, they most likely pulled that wiring down, it has to be in the side panel.
Alice's .:Project Yuki:. | 08-15 Ford E350 Extended Passenger Van (Preferably a Power Stroke Diesel)
AliceSML79
Projects
02-04-2017 01:47 AM
tlrtucker
03-07-2016 07:15 PM
