how do you get to sparkplug #6?
I have a 2002 Explorer Sport with a 4.0 liter engine and I changed 5 out of the 6 plugs. How do you get to the #6 plug? It is right up aganst the air conditioning housing up by the fire wall and there is a gap of about 1-1/2 inches between the valve cover and the a/c housing. I can't even get my hand down there.
any help is appreciated.
Thanks,
Ken
Thanks,
Ken
No that is #3 - on the passenger side rear. It's loads of fun huh? I have never had a problem getting to it on my 93. I just go over the top with a regular socket and ratchet. You have to get down in there for sure but you can get it. Some folks have had better luck removing the right front wheel and the plastic wheel well and then there it is. Alos look at it from underneath the truck - might be easier.
I don't know what the big deal is. Maybe the later model ones have more AC crap in the way. My 93 is right there from the top. I just use a regular 6" long ratched with a regular plug puller. No swivels or extensions. I even have headers on mine. Now the hard part for me is getting the rubber plug wire boot off the plug. No room in there to grab it. So I use a long flat screwdriver and kind of pry off the head to work it off.
I guess soemthing change. Glad I have it easy.
Here's a couple tips for changing plugs: First pick up one of those spark plug wire removal tools. They look like a long pair of pliers, and make it easy to access and remove the wires without damage. Cost is about 3-4 bucks.
Then get a short section of vacuum or fuel hose that will fit over the end of the plug. Use this to insert the new plugs and start the threads.
I like to use a dab of anti-seize compound on the threads, to make the job easier next time.....
