custom headers - Ford Truck Enthusiasts Forums
custom headers
Old 09-14-2002, 11:19 PM
79 390 highboy 79 390 highboy is offline
79 390 highboy is starting off with a positive reputation.
custom headers
ine 1 know were i cam get a custom set of headers for my 79 with a 390 in it
Old 09-15-2002, 10:25 AM
wildebeast wildebeast is offline
wildebeast is starting off with a positive reputation.
custom headers
try www.pawengineparts.com and order there catalog i just ordered a set for my 77 360 highboy but a 79 didnt come witha 390 so i dont know if they will have a application for that
Old 09-15-2002, 01:43 PM
proeliator proeliator is offline
proeliator is a splendid one to beholdproeliator is a splendid one to beholdproeliator is a splendid one to beholdproeliator is a splendid one to beholdproeliator is a splendid one to beholdproeliator is a splendid one to beholdproeliator is a splendid one to behold
custom headers
www.stans-headers.com
If he doesn't have a pair in stock that will fit, which I bet he does, he will make them for you. They are also among the very best you can get. I run them myself.
Old 09-15-2002, 04:36 PM
gray79f250 gray79f250 is offline
gray79f250 is starting off with a positive reputation.
custom headers
I second the stans headers they are awesome quality and craftsmanship
Old 09-15-2002, 10:18 PM
Crowbar65 Crowbar65 is offline
Crowbar65 is starting off with a positive reputation.
custom headers
Old 09-16-2002, 01:06 PM
jalampi jalampi is offline
jalampi is starting off with a positive reputation.
custom headers
Good Luck! I have been looking on and off for about 12 years now. Nobody has them for this engine frame combination. They would have to be custom made. Let me know if you find some!
1979 F350,4x4,NP435,5:13 gears,Detroit locker in rear with hardened shafts,ABR in the front,L&L Ladder Bars,360 with 428 crank & rods,390 HP heads,Centerforce Dual Friction Clutch,MSD Ignition,39.5x18 Boggers,bucket seats out of a Lightning,& a Southern Body that is perfect.
1997 F350 PowerStroke 4X4,36 Inch Super Swampers, Strait Piped, Chiped, Propane Injected, LUK Clutch
Old 09-16-2002, 01:12 PM
tw's Avatar
tw tw is offline
tw is starting off with a positive reputation.
custom headers
I put a 390 in a 78 1/2 ton last year. I just ordered headers for a 76 with a 390/360. They worked just fine. I also used the motor mounting perches from a 76, that could make a difference.
Tony Warren
Nebraska
Old 09-16-2002, 01:20 PM
custom headers
[updated:LAST EDITED ON 16-Sep-02 AT 01:21 PM (EST)]3/4 & 1 ton 4x4 frame is different from the 1/2 ton.
Old 09-16-2002, 11:45 PM
dinosaurfan dinosaurfan is offline
dinosaurfan is gaining momentum as a positive member of FTE.
custom headers
Jalampi, 12 years ?! Where have you been looking ? Yes, I have a bit of CRS disease, but if I am remembering rightly today, the frames of the 73-79 4wd drives are mostly the same. So why can't you use the headers intended for a 75 or 76 F250 4wd ? Some, (but not all) of the later frames have the rails spaced farther apart, should give you more room, easier fit. Did you want 4 into 1s- try hedman 89120 or superduty 89830. Did you want a set of tri-Ys, Stan's 244YL. How about shortys, Sanderson FF427s. Or fenderwells, Thorley THY-264. really now , 12 years ? I found these searching for less than 5 minutes, with a dial-up modem even. You can call and order a set from the manufacturer of your choice tomorrow AM. DF
Old 09-17-2002, 10:24 AM
custom headers
It appears we have an expert on the subject mater.:-staun
79 390 Highboy- Post your results if you find a set that will work in this application.
Headers on a 79 ford 390? Ford59galaxie 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-01-2012 01:21 AM
1979 F250 with 390 custom headers, help! heikks 1973 - 1979 F-100 & Larger F-Series Trucks 2 04-22-2009 03:52 PM
'76 F-250 4x4 390 headers on '79 F-250 390 poorfolks Engine Swaps 4 04-13-2005 07:07 AM
Flowtech Headers..............390 BrettCox 1967 - 1972 F-100 & Larger F-Series Trucks 3 08-30-2002 12:21 PM
390 Headers & Exhuast system Nathan Exhaust Systems 1 05-19-2000 10:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
