Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > 4 Cylinder Engines
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 08-23-2005, 02:44 PM
R-Man12 R-Man12 is offline
R-Man12 is starting off with a positive reputation.
2.3 Vs. 2.5
OK...what are the differences in the two engine blocks-2.3 and the 2.5? Are there any diffenences and if so what are they?
  #2 (permalink)
Old 08-23-2005, 03:19 PM
AlfredB1979 AlfredB1979 is offline
AlfredB1979 is starting off with a positive reputation.
The OBD1 engine (94 and earlier) is a different animal than the OBD2 2.3L and 2.5L Limas.
Internal (bore x stroke) is different and some external sensor locations are different between the OBD1 and OBD2 setups.
  #3 (permalink)
Old 08-23-2005, 03:36 PM
Are there any other differences as far as anything else that would make the 2.5 better than the 2.3? Basicially, if the only diffenences is the bore and stoke, y cant I just put a 2.5 crank in a 2.3 block? I race at a local dirt track so the engines use carbs. so the sensors arnt necessary. Just tryin to figure out what some other racees may be doin different to give them an advantage. Need some help!
  #4 (permalink)
Old 08-23-2005, 05:05 PM
rusty70f100 rusty70f100 is offline
rusty70f100 is gaining momentum as a positive member of FTE. rusty70f100 is gaining momentum as a positive member of FTE.
If you're going racing, you might check these guys out:
http://esslingeracing.com/index.htm
In a stock block, they have stroker cranks that will take the 2.3L up to 2.85L.
  #5 (permalink)
Old 08-23-2005, 05:28 PM
Yeah I know all about that company but I just need to know the differences (if any) between a stock 2.3 and stock 2.5 block.
  #6 (permalink)
Old 08-23-2005, 07:26 PM
I think the 2.5L has smaller main bearings.
  #7 (permalink)
Old 08-24-2005, 08:03 AM
tomw tomw is offline
tomw is gaining momentum as a positive member of FTE.
The stroke is longer in the 2.5. You would have to have a set of pistons and rods if you swapped the crank. The lima block did change bearing sizes, and if you fish around on this site, you will find the specs, by year. The distributor disappeared after a while, they added a crank pos sensor and a cam pos sensor, etc for distributorless ignition.
Essentially, the same engine since 1974. Modded & tweaked, but the same basic design.
tom
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
  #8 (permalink)
Old 08-24-2005, 10:37 AM
The racetrack we run at, all the Fords are using the 2.3 block and puttin the 2.5 crank in it. If everything is the same besides the rods and pistons, why arent they using the 2.5 block? Is there somethin in the 2.5 block to give them an advantage?
  #9 (permalink)
Old 08-26-2005, 08:58 AM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of
Hey, R-Man12! Sorry I didn't give you welcome when you first posted here, so I'll do it now. Welcome to FTE! Please check out the guidelines, they contain important info you need when posting here. Here's a link:
http://www.ford-trucks.com/guidelines.html
Do your track rules specify stock parts only, or are you allowed a little leeway?
When I raced a mini-stock, I ran the 2.0 ('71-'74 Pinto/Capri version) but I built a few 2.3s for a friend. Now my co-worker wants to get into it and has decided on the 2.3, mostly for parts availabilty.
Here's my thought on the 2.5 block: Many tracks won't allow a crank trigger ignition, it's usually distributor only. When crank triggers first appeared on the 2.3, they merely plugged the hole where the distributor went. Now, I can't swear to this for sure, but I believe the 2.5, being a newer engine, is strictly crank trigger and has no provision for a distributor so most folks will stick with the 2.3 block for that reason. There may be another reason but that's what occurs to me.
Of course, it's still early in the morning and the brain isn't fully functional yet so I may be way off base here.
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #10 (permalink)
Old 08-26-2005, 01:25 PM
OK thanks 4 your help. Is there any other differences in the 2.3 block and the 2.5 block that u know of?
  #11 (permalink)
Old 08-29-2005, 03:08 PM
460429_freak's Avatar
460429_freak 460429_freak is offline
460429_freak is starting off with a positive reputation.
yes the later 2.3 had a small journal crank perfect for the 2.5 crank
__________________
Can't list my Ford's only allowed 300 letters.... to many to list
FORDS always look better when pulling a CHEVY
  #12 (permalink)
Old 09-07-2005, 11:06 PM
RacinNdrummin RacinNdrummin is offline
RacinNdrummin is new and has a neutral reputation at this point.
The 2.5 block is a distributorless block and has no hole, I found this out when tearing out a 2.5 engine of a ranger for my pinto.
__________________
74/71 maverick grabber EFI HO (under construction)
05 ranger 3.0/5spd supercab
90 Bronco II, 4.0 swap (UC) 5-speed, 4x4, factory D35
6" lift 33's 8.8...
91 Mustang LX 5.0 Coupe (new engine being built now)
91 E250 4.9 c6 3.73
95 F-150/SB/SC 351w swap, 3.55, 4r70w (Dads truck)
  #13 (permalink)
Old 09-16-2005, 09:22 PM
Bart99GT Bart99GT is offline
Bart99GT is starting off with a positive reputation.
The auxillary sprocket only drives the oil pump on 95+ 2.3L and all 2.5L engines. There is no provision for a distributor and marks the first really significant change in the block design since 1974. There are a couple of years of 2.3L blocks that use the smaller main bearing journal diameters and can still run a distributor. Actually by using a spacer the 2.5L crank can be used in any 2.3L block as long as you're careful with the tolerances. There's a guy on the SVOCA site who has done just that with his stock 1984 2.3L block.
__________________
1995 Ranger XLT SuperCab, SOHC 2.3L, Mazda 5-speed
1986 1D Mustang SVO
  #14 (permalink)
Old 10-01-2005, 08:47 PM
pntrbl pntrbl is offline
pntrbl is starting off with a positive reputation.
RMan-12, just look for a block from the early 90's. Make sure it has a rubber plug where the dizzy used to be and a crank trigger ignition. That will be a 2.3 block that has the smaller main journals the 2.5 crank needs. No spacers required. Put a 2300 Aux shaft in to run a standard diz and your good to go.
Well, except I don't think it'll have a hole for the mechanical fuel pump! I've heard you can cut it out yourself but I'd rather run an electric.
The 2500 rods are 5.45 in length but no one seems to use them much. The 5.2 length from the 2300 gets used all the time but it's too short for the 2500 crank. Better is a set of Crower 5.7's and that might be where the competition is getting the HP on you. Longer rods make the pistons spend a little more time at the top and the bottom of the stroke (increased dwell is the technical term) and another advantage is they get to work at less of an angle.
With the longer rods you'll need the correct pistons so they don't go poking out of the bores but they're readily available from Racer Walsh, Esslinger, Race Engineering, Midwest Motorsports, etc.
Gonna take some money tho. Grover Cleveland is on the thousand dollar bill and it'll eat up a couple of Grover's.
  #15 (permalink)
Old 11-18-2005, 08:28 PM
uuranium's Avatar
uuranium uuranium is offline
uuranium is starting off with a positive reputation.
are you running an svo block or just a standard block?
Tags
23 , 23l , 25 , block , coupe , deck , difference , ford , identify , l , liter , mustang , speed , svo , tall , turo , versus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
