tachometer feed 1994 Superduty 460
Old 08-23-2005, 11:30 AM
aaron59's Avatar
aaron59
aaron59 is offline
I am trying to install a tachometer and not sure where to attach the tachometer signal feed. The instructions say to the negative side of the coil? Is there a wire or terminal already in place etc.
Old 08-23-2005, 03:08 PM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 08-23-2005, 03:15 PM
handyman43358's Avatar
handyman43358
handyman43358 is offline
You'll have to add a connector to put on the negative side of the coil.
Old 08-23-2005, 03:45 PM
aaron59's Avatar
aaron59
aaron59 is offline
At first look I havent been able to find a coil, at least not one like I am used to on older vehicles with non electronic ign. If I trace a sparkplug wire back, will I find a distributor and then a coil?
Old 08-23-2005, 05:33 PM
SVTCobra306's Avatar
SVTCobra306
SVTCobra306 is offline
Trace the center wire out of your distributor, it should lead to a small square frame containing a round coil with an electrical connector coming in right underneath the coil wire.
Hook your tach lead to the wire on the left as you face the plug when it's plugged in.
Old 08-25-2005, 07:00 PM
aaron59's Avatar
aaron59
aaron59 is offline
Thank you so much, the tach is operating just fine.[B]One more quick question, what is the red line on this engine?
Old 08-25-2005, 07:47 PM
handyman43358
Which engine is it?
Old 08-25-2005, 10:45 PM
SVTCobra306
He said earlier it's a 460. Probly around 5000 RPM stock, but the big block may be less. I haven't worked with one yet personally.
I set mine by where the motor ran out of steam. 4500 is pretty much it, so I set the redline at 4800. Ford EEC shuts fuel off at 6250 RPM on most engines (4.6L is an exception, it's higher on the performance versions...)
Old 08-27-2005, 09:08 AM
handyman43358
Sorry I didnt see that he said it was a 460. Not sure about a big block, but I know my 351 doesnt show a red line on the tach. It just stops at 6 grand. Im never able to get it past 3800 b/c it shifts before that point, even if I'm stomped to the floor.
Old 08-27-2005, 03:21 PM
SVTCobra306
I've gotten mine to 4500 before it shifts...
Old 08-27-2005, 05:25 PM
handyman43358
My engine is pretty well wrapped out at about 3500-3800 when it shifts. It has its most power at about 3500 for some reason, should be more at higher rpm but its not.
miashley150
13
08-22-2013 11:34 AM
ZHMMY
09-28-2011 03:27 PM
Bax2008
Aerostar
01-11-2008 08:23 PM
rob_n_houston
1999 to 2016 Super Duty
12-05-2001 09:16 PM
josh3972
Bronco II
10-13-2001 11:02 AM
Quick Reply: tachometer feed 1994 Superduty 460
