48-52 Dash Insert - How to secure?
on
My old F-3 came with nothing but a hole in the dash where the instrument panel goes. I bought an aftermarket aluminum insert which takes modern gauges. The insert fits the hole in the dash fine but what holds it in place? Was I supposed to get some kind of bracket with the insert or is it held in place like the original gauge panel somehow? What did you guys use to hold yours in?
Vern
Vern
Vern
If I'm understanding you correctly, what you have is a flat piece of metal with holes in it.
If so that is supposed to replace the flat original piece that was mounted to the origanal instrument cluster holder thingie. The thingie is oval shaped and about two inches deep (I'm doing this from memory as I can't navigate the steps today.) and this is what bolts/screws to the back of the dash.
If I'm not correct I at least hope I added to the confusion.
I just finished putting a dash insert in my 50 with dolphin guages, as Barry stated there should be 3 studs on the back side of your dash opening, my insert came with 3 "tabs" that were drilled to fit over the studs and hold the insert in place. very simple to make if your insert came with out them.
Alan
Alan
on
Alan
Alan
Can you describe those "tabs" that came with your insert in more detail? Are they just 'L' shaped brackets? Mine came with nothing. I do have three studs that come out of three tabs coming off the back of my dash but they are spaced out an inch and a half from the dash and the insert is basically flat so I'm wondering how I get from the studs to the insert to retain it.
Vern
Tombstone Todd
07-17-2012 04:45 PM
F250SDPowerStroke
1999 to 2016 Super Duty
10-08-2005 11:08 AM
