'79 F 250 4x4 460 swap - Ford Truck Enthusiasts Forums
Old 08-18-2005, 01:09 PM
Ford4x4CountryBoy Ford4x4CountryBoy is offline
Ford4x4CountryBoy is starting off with a positive reputation.
I just bought a 79 F250 ranger 4x4 with a 400 with a 4 speed, 4:10 gears. I'm buying a 460 from a '78 van to swap into it because the 400 has a knock, from what i'm told it has the right rear sump pan, and the right exhaust manifolds, what i'm wondering is what else do i need to swap this motor in, motor mounts, flywheel, anything else...thanx
Old 08-18-2005, 02:59 PM
catmandu79 catmandu79 is offline
catmandu79 is starting off with a positive reputation.
460 Swap
You will need all the 460 accessories,Alt.,PS Pump,etc. If you are going to keep the 4speed tranny, check the clutch and TO bearing and replace if needed while you will have it all apart, the 400 flywheel/pressure plate will bolt right up, if you are using an Automaggit it will bolt right up as well. You will need the 460 radiator, the one for the 400 will have you overheating quick! The Exhaust will need to be altered! You will need to upgrade your fuel system to handle the larger motor, smallest carb for 460 using VE calculations is a 750CFM. DO NOT REUSE OLD HARDWARE!!! New hardware is inexpensive enough this should be a no brainer, but some believe that the old hardware is good enough, until something BAD happens! And last but not least you will need new motor mounts, the towers have enough material to alter them for a good fit.
Old 08-19-2005, 07:49 AM
toddn78 toddn78 is offline
toddn78 is starting off with a positive reputation.
I'm not so sure about using the 400 flywheel and clutch. everything else i have read on these forums say you have to change them even thought they will bolt right up. I think it will mess up the balance of the motor.
78 F-250 460 swap Kawi444 1973 - 1979 F-100 & Larger F-Series Trucks 1 02-19-2015 11:12 PM
1984 2wd 460 swap into a 1978 4wd F250 with the 400m automatic oregontrailsman Engine Swaps 4 11-12-2014 08:12 PM
New question: 85 460 into 79 F150 radramrod2 Engine Swaps 1 12-06-2012 12:59 PM
headers for a 4x4 460 swap crazed87bronco 1973 - 1979 F-100 & Larger F-Series Trucks 28 02-07-2011 02:50 PM
79 4x4 390 or 460 trickf100 1973 - 1979 F-100 & Larger F-Series Trucks 2 09-09-2004 09:39 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
