Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Michigan Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Michigan Chapter Join Chapter, Leader: just another truck
  #1 (permalink)
Old 08-17-2005, 05:30 PM
The Yooper The Yooper is offline
Garage is empty, add now
The Yooper is starting off with a positive reputation.
Lightbulb Any mechanics to help identify this part
On a 1975 Ford F-100 V-8 column shift, auto trans. Neighbor calls it a 'neutral switch actuator' and it is positioned on the shifting tube. It is on the tube under the dash and sort of snaps on to the tube with a point or lever sticking off of it so that it will actuate the lever on a switch box there. It is metal and in a way half moon shaped so that it fits part way onto the shifting tube and is moved when you move the lever on the steering column. Any references or sources that you might suggest would be helpful.
Thanks, Jim
  #2 (permalink)
Old 08-21-2005, 11:24 AM
ranger pat's Avatar
ranger pat ranger pat is offline
1956 Ford F-100
My Garage
ranger pat is starting off with a positive reputation.
Yooper, I would start with looking in a shop manual for your year. I don't have the correct year manual, but there are some steering column breakdown illustrations that show internal parts for a/t column shift. My guess would be you will have to hunt down the part in a local wrecking yard. Try posting your problem in the F-Series forum for 1977 models. There would be more people with 1977 experience than in the Michigan chapter.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
