running and dash lights kaput
The most obvious thing to check is the switch. It's common for them to fail. If the headlamps are out, check the dimmer switch, these get crusty. You can jump the dimmer by finding the power source and jumping to the low-high beam wires. if they now work, dimmer is bad. If you don't have power there, trace back to switch.
check the fuse, if good, trace to switch and see if there's power into the switch. It might be a good idea to get a wiring diagragm for your truck. Others will list where they're available on the web.
Barry
Barry
