99 F150 Pcm?? - Ford Truck Enthusiasts Forums
99 F150 Pcm??
Old 08-17-2005, 08:13 AM
jersford jersford is offline
jersford is starting off with a positive reputation.
99 F150 Pcm??
I have a 99 F150 5.4. 96,000 miles. Been running great, one morning truck will start but shut down in about 5-10 secs. I borrowed a code scanner but didn't retrieve any codes. I have replaced fuel filter, pcv valve. I have checked cam pos. sensor, voltage at fuel pump relay and at fuel pump. If I spray starter fluid in the intake truck will continue to run. PCM, and fuel pump relay working. It's like something is telling the fuel pump to stop? I am hoping I am overlooking something simple and the problen isn't the PCM. Any Ideas?
Old 08-17-2005, 08:30 AM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
..See you on the boards.
Old 08-17-2005, 09:06 AM
furrby furrby is offline
furrby is starting off with a positive reputation.
i would check the pressure regulater or injectors. if the pump is got power and is pumping. then there is the only to thinks i can think would cause your problem.
furrby
Old 08-17-2005, 10:54 AM
furby
Is there a way to check the Fuel Pressure Regulator?
Old 08-17-2005, 03:07 PM
l-m tech l-m tech is offline
l-m tech is gaining momentum as a positive member of FTE.
have you cleaned the idle speed motor.it wont set a code unless it is shorted.actuators usually dont tell on them selfs,if the pcm tells it to work it does.
Old 08-17-2005, 03:10 PM
I have just finished replacing the IAC valve -no luck, Idle speed motor?
Old 08-17-2005, 03:22 PM
I have looked in Haynes Repair Manual, no mention of Idle Speed Motor? Not even in wiring Schematic?
Old 08-17-2005, 03:24 PM
what about the crankshaft pos. sensor.
Old 08-17-2005, 03:26 PM
the people on this mess. board call it a idle speed motor,in the dealer world its called a iac
Old 08-17-2005, 03:29 PM
get a fuel press. gauge and see if the fuel press. is falling off. you could have power to the pump but the pump could be getting weak.
Old 08-17-2005, 09:43 PM
ccoram ccoram is offline
ccoram is starting off with a positive reputation.
Sounds like a weak fuel pump - even though its pumping, the volume and pressure might not be enough to run the truck.
Old 08-18-2005, 12:15 AM
Fasterhorses Fasterhorses is offline
Fasterhorses is starting off with a positive reputation.
There is a filter in the tank attached to the pump. You might have got a tank of dirty gas and it plugged that filter. You can try blowing with low pressure air backwards thru the fuel outlet hose then try running the motor. If it keeps running then you will have to drop & clean the tank & replace the pump cause the filter will clog up again real soon.
Old 09-16-2005, 02:06 AM
SkorpioN SkorpioN is offline
SkorpioN is starting off with a positive reputation.
just a silly question but did you check to see if the PCV hose was in good condition when you changed the valve as these are known for accumalating vac leaks
2003 f150 fuel problem gonzales 1997 - 2003 F150 16 01-06-2017 09:25 AM
Fuel delivery issue... roughridn_sob 1987 - 1996 F150 & Larger F-Series Trucks 22 06-18-2014 07:45 PM
06 F150 Fuel Pump Won't Stop ster1 2004 - 2008 F150 4 01-25-2014 02:00 PM
No spark, no power to fuel pump!! 87BigBronco 1978 - 1996 Big Bronco 5 07-28-2011 09:04 PM
Testing a PCM?? cajunbull61 2004 - 2008 F150 9 02-17-2009 07:01 PM
Tags
150, 99, changing, f150, located, location, pcm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
