ignition makes clicking noise, won't turn over, is not the battery - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 08-16-2005, 02:54 PM
pdonald pdonald is offline
pdonald is starting off with a positive reputation.
This is a '93 Ranger with the 2.3L 4 cyl engine- the ignition lock and the starter solenoid were both replaced but it still won't start. The starter solenoid makes a "clunk" sound, it doesn't make the "tick-tick-tick" sound like a dead battery, it has plenty of juice in the battery. Any suggestions, or how do I trouble-shoot the ignition at this point? Thanks for your help.
Old 08-16-2005, 03:26 PM
big6-87bronco's Avatar
big6-87bronco big6-87bronco is offline
big6-87bronco is starting off with a positive reputation.
Do you mean the starter solenoid that is on the starter or the starter relay on the fender is making the clunk sound? If you are talking about the solenoid on the starter I would take the starter to a local parts place like Napa or Advance to get it tested.
I have a 95 mazda 2.3 and every now and then when I try to start it the starter relay on the fender will make one loud click and not start. After a couple more tries it will start with no problems. I am leaning towards the relay on the fender or possible ignition switch. My starter is only 4 months old and the battery is fine.
The first thing I did was check and clean all of the cables and connections from the battery to the relay to the starter. It still does it once in a while and it is hard to trace when it works most of the time.
Old 08-16-2005, 04:40 PM
We replaced the starter relay on the fender, and the ignition lock cylinder. We cleaned the battery terminals and tested the battery, which tested as a good battery. We haven't gotten down to the starter or the starter solenoid. There's no easy way to check the starter without removing it, is there?
Old 08-16-2005, 05:37 PM
moat's Avatar
moat moat is offline
moat is starting off with a positive reputation.
To test the starter, you could just use a jumper cable directly from the battery's +, touched to the starter's cable mount lug. If it spins, your problems are upstream. Does sound like the starter is kaput, tho.
Old 08-16-2005, 09:14 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
I'm thinking a bad cable or connection since the solenoid engages and holds.
Old 08-16-2005, 11:36 PM
el conquistador el conquistador is offline
el conquistador is starting off with a positive reputation.
I agree with ken, check the battery cables.
Old 08-17-2005, 07:56 AM
How do I know that the solenoid is engaging and holding?
Old 08-17-2005, 08:40 AM
dillonboys dillonboys is offline
dillonboys is starting off with a positive reputation.
I had the same problem-it was the red(small) wire at the starter sol.
I would take it off and put it back on and the truck would start.I replaced the end with a better connector and the problem went away.good luck
Old 08-17-2005, 10:40 AM
It must have been the starter, we banged on the side of it and it finally started. Thanks for all the tips.
Old 08-17-2005, 10:48 AM
jinx102672 jinx102672 is offline
jinx102672 is starting off with a positive reputation.
If it is the starter, which it seems to be the case, you may want to look into replacing the pick-up brushes on the inside. A rebuild kit is cheaper than a new starter.
Starter solenoid? Checking starter? mOROTBREATH 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 09-24-2013 08:01 PM
55' F100 Starter, Ignition, Solenoid....Hmmmm JoeSwing78 1948 - 1956 F1, F100 & Larger F-Series Trucks 34 08-23-2013 06:53 PM
starter solenoid fails mike2112 1987 - 1996 F150 & Larger F-Series Trucks 5 04-11-2010 10:26 AM
Engine won't turn over? MBBFord 1973 - 1979 F-100 & Larger F-Series Trucks 18 12-10-2007 03:16 PM
1991 ford explorer 4.0 starter issuses?? rneutron Explorer, Sport Trac, Mountaineer & Aviator 9 04-09-2005 10:46 AM
Tags
94, b2300, clicking, ignition, makes, making, mazda, noise, turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
