Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-15-2005, 11:38 PM
dogdude2003 dogdude2003 is offline
Garage is empty, add now
dogdude2003 is starting off with a positive reputation.
Propane injection or 2nd Diesel tank?
My range sucks when towing my 5th wheel. AND I hear propane injection increases mileage, power and range.
I can't afford both... which one is best?
Propane injection my void my warranty or be difficult to take out if I have to take my truck to the dealer.
The extra fuel tank instead would be no problem...but would be heavier and would cost a fortune at the pump.
any suggestions?
__________________
2007 3500HD Duramax/Allison Crew LongBox.
2004 F-350 Diesel Lariat Metallic Green 6.0
Lemon! Sued Ford and Won. (GONE!).
  #2 (permalink)
Old 08-16-2005, 05:07 AM
HeavyAssault's Avatar
HeavyAssault HeavyAssault is offline
HeavyAssault is gaining momentum as a positive member of FTE.HeavyAssault is gaining momentum as a positive member of FTE.
>>>SCT XCALIBRATOR - EDGE JUICE ATTITUDE STACKED, MAGNAFLOW EXHAUST AND K&N INTAKE
And you are worried about the warranty?? I'd say go for the propane, but the larger/extra tank should give you more mileage overall.
__________________
http://i257.photobucket.com/albums/hh239/HeavyAssaultF350/DSC00396-1.jpg
  #3 (permalink)
Old 08-16-2005, 05:27 AM
BigF350 BigF350 is offline
2000 Ford F-350
My Garage
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
adrian.erks.harris adrianerksharris
One of the benefits of a larger range tank is you can be more choosey with where you purchase your fuel from.
i.e. You can hold off that little longer until you reach a town where the price is so and so, and fill up there.
Having a larger tank can actually be quite benefitial financially, without even realising it.
BTW. You don't say whether you have a short or a long bed - I assume you have a long bed because you tow a 5'er. Is that correct?
__________________
Adrian | 2005 4x4 Diesel Ranger CrewCab in Aus | 2000 4x4 SC/LB F350 7.3 ZF-6 in the US
  #4 (permalink)
Old 08-16-2005, 09:51 AM
I have a short bed. And I realize your point about being choosy and such...I've researched the Transferflow in the bed tool box fuel tank and it's $1749 installed. That is very pricey!! It seems too expensive to me. I looked at the Northern Tool version and it's much cheaper...why? What's the story here?
And to address the point about my SCT and EDGE unit and warranties:
The SCT can be flashed to stock in 10 minutes. The Edge can be uninstalled for a trip to the dealer in 10 minutes. Propane injection? Seems too complex to just uninstall....but I don't know. Anyone?
__________________
  #5 (permalink)
Old 08-16-2005, 10:00 AM
2000 Ford F-350
My Garage
Ouch. $1749 isn't cheap at all. Seeing you have the shortbed, I understand your dilema though.
I have heard good reports about Transferflow, I don't know about Northern Tool. I understand Transferflow make a 40+ gallon under bed replacement tank. How much does that cost?
I would also imagine that removing all evidence of a propane system would be quite difficult. However, the people that run propane will probably chime in and confirm or deny.
  #6 (permalink)
Old 08-16-2005, 10:07 AM
The problem with the under the truck tank is ground clearance and the very expensive 4x4 package skid plates I have down there. I'm in an area where I go off road from time to time. The under the truck tank is the same price or around the same as the Northern tool truck bed tank. Might as well get the extra tank if I go that route.
__________________
  #7 (permalink)
Old 08-16-2005, 05:38 PM
It is still traceable by the dealer if they need to dig hard enough from what has been posted in the past. You could set up the propane in the bed of the truck.
I'm not trying to start anything, it just seems as you are already into the power mods. Propane is a great thing, but for what you have posted so far I would recommend an aftermarket undertruck replacement tank for the greater range.
__________________
  #8 (permalink)
Old 08-16-2005, 06:17 PM
The SCT and EDGE cannot be detected if they are removed. And...I've removed them about 10 times for service at Ford...If you are talking about P0603, it's a memory blirp in the PCM and doesn't prove a mod was present. If I was worried about it, I'd just disconnect the batteries and reset the memory....
As far as the propane...I'd love to put it in...but don't want to have to fight Ford with Magnuson Moss in court over a warranty issue.
__________________
  #9 (permalink)
Old 08-16-2005, 07:18 PM
mrcobra350's Avatar
mrcobra350 mrcobra350 is offline
mrcobra350 is starting off with a positive reputation.
tough decision dogdude. I have a short bed too. I have a 100 gallon tank that I took out of my old truck when I traded it. It was a long bed. Now I have a roll top cover and a fifth wheel hitch. It would take a months pay to fill up the tank so I think I am going to sell it and buy about a 40 gallon that is L shaped that can slide under the roll top and give me more range when towing my 5th wheel
Good luck with your decision.
__________________
Rick Carson
My Rides:
04 F250 Crew Cab,2X4,Short bed,
06 Screaming Yellow GT
04 Mustang GT
88 Crown Vic LX
70 Mach 1
85 Goldwing Limited Edition
50 Ford Custom
List Mod's in Gallery
FTE
  #10 (permalink)
Old 08-16-2005, 07:37 PM
SpartanDieselTech's Avatar
SpartanDieselTech SpartanDieselTech is offline
FTE *******
SpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to all
There are some of whom you will never convince of that... Just ignore it and go on
  #11 (permalink)
Old 08-16-2005, 08:05 PM
PSD...please weigh in on the propane injection
__________________
  #12 (permalink)
Old 08-16-2005, 08:13 PM
FTE *******
If your looking for extra range go with another tank of diesel.
Personally, I don't think that highly of propane. It works, it's effective, but IMO it's just a cheap excuse for a bigger set of injectors and a better fuel system, if power is what you are shooting for
  #13 (permalink)
Old 08-16-2005, 08:51 PM
Mud Doc Mud Doc is offline
Mud Doc is starting off with a positive reputation.
The TF tank transfers fuel automatically using a pump; the NTool is either a gravity feed into the filler line, or an extra pump that is activated by a solenoid switch--both are extra cost. I've been looking hard at the NT tank, but havent decided.
__________________
2009 F450 Lariat CC 4x4
2005 Mobile Suites 36TK3
2011 MKX
  #14 (permalink)
Old 08-16-2005, 09:35 PM
Yes..the TF is an automatic and very nice. It's definetly top of the line...but $1700+ dollars?? The NT is a switch in-cab and holds 51 gallons instead of 30. The NT is almost $900 bucks with the diesel transfer stuff. The TF is $1400+ install of $300. It's basically a difference of $500 bucks. And 20 extra gallons vs. automatic filling and digital control in-cab. Also the TF is made in Chico which is 4 hours from here. I could drive there if I had issues and the factory would support me. There is a dealer 40 minutes from here who would do the install and support also and they are very cool and very honest. Again...the NT tank is an additional 20 gallons and is basically the same concept....I'd still get it installed professionally and not spend the 2 days it would take me on my own with no help. Plus...the NT would have to be shipped to my Nevada address (a relative) and that is 1 1/2 hours away...then haul it back here and spend the time installing it.
Decisions decisions. My wife finally said...do we really need it? Diesel is $3.50 here. It would cost us a fortune to fill both tanks!
__________________
  #15 (permalink)
Old 08-16-2005, 10:44 PM
pickupman2002 pickupman2002 is offline
pickupman2002 is starting off with a positive reputation.
i dont know that much about propane but i think adding more fuel storage would make more sense. about the cost of fueling a bigger tank i dont see why that is a big deal if a trip takes you 100 gallons a fuel its going to cost the same in you fuel up four times or just once, of course as long as the fuel is the same price.
Tags
injection, propane, tank
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
