Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
  #1 (permalink)
Old 08-15-2005, 08:44 AM
1988f150pu 1988f150pu is offline
Garage is empty, add now
1988f150pu is starting off with a positive reputation.
Antifreeze foaming
I have a 1988 F-150 and the other day I was pulling my horse trailer with 2 horses to have them shod. I went about 20 miles. When I arrived I unloaded 1 horse and was standing by the truck when the Antifreeze started to foam out of the overflow hose on the radiator. Any ideas why??? I checked for leaks and found none. It also has no been running hot..
  #2 (permalink)
Old 08-15-2005, 08:58 AM
BillyBob69's Avatar
BillyBob69 BillyBob69 is offline
BillyBob69 has a great reputation on FTE.BillyBob69 has a great reputation on FTE.BillyBob69 has a great reputation on FTE.BillyBob69 has a great reputation on FTE.BillyBob69 has a great reputation on FTE.BillyBob69 has a great reputation on FTE.
Check your oil to see if it is milky or has bubbles. If so, then you have a leaking head gasket which is allowing the antifreeze to mix with the oil. This is what usually causes the coolant to foam up.
__________________
99 F350SD Lariat Crew Cab 7.3L PSD - 4x4 - DP Tuner - Custom HD trans
86 Bronco 302 EFI (Second one!)
Quit whining! You voted for him!
http://i86.photobucket.com/albums/k102/billybob69_photo/90x90_email_signature_HIGHMILER-1.png
  #3 (permalink)
Old 08-15-2005, 03:32 PM
gfreek gfreek is offline
gfreek is starting off with a positive reputation.
Could you have had too much cooant in the tank? If not then I would keep an eye on it and the temp gauge. You might want to have someone check to see if there is combustion gases in the coolant, which would mean a blown head gasket.
  #4 (permalink)
Old 08-15-2005, 05:28 PM
PaulC PaulC is offline
PaulC is starting off with a positive reputation.
One possibility is that the engine DID become very hot while driving. When you stopped the engine, the water pump stopped circulating coolant and the engine fan was unable to cool the antifreeze then residing in the radiator. The residual heat from the engine caused the cooling system to overpressurize and release pressure and coolant through the hose.
Another possibility is that the transmission became very hot, and the high transmission fluid temperature contributed to the coolant release. The factory transmission cooler runs a line through the radiator.
If you don't have one already, I would consider adding an aftermarket transmission cooler to your truck. Unless those horses are on a diet, you're giving this truck a heck of a workout, particularly in this weather. Excessively hot transmission fluid can change properties and damage a transmission. $$$
__________________
1999 Expy XLT 4x4 4.6
October 7, 1998 - April 26, 2006
Served me well.
Tags
73, 97, antifreeze, coolant, f150, fluid, foam, foaming, foamy, ford, leaking, milky, overflow, radiator, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
