Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #61 (permalink)
Old 01-24-2006, 08:02 AM
03redstx 03redstx is offline
03redstx is starting off with a positive reputation.
Quote:
Originally Posted by kspilkinton
What type of pistons does the 4.6 DOHC Cobra engine run, and what's the block made out of? This might have something to do with the weight of the oil.
-Kerry
Depending on which year you are talking about. I have a '98 Cobra and the block is an aluminum Teksid Block. The new supercharged blocks are cast iron. The pistons are domed forged units.
  #62 (permalink)
Old 01-24-2006, 04:49 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of
The Terminator engines (Supercharged) should have dished pistons for lower compression which are forged along with a cast iron block and a steel crank.
The 5.4L is taller and it takes longer for the oil to reach the heads
Also, the Cobras are made to be driven in nice weather, not in the winter time muck. (at least mine would be)
The hand build Cobra engines probably have different bearing clearances too.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #63 (permalink)
Old 01-24-2006, 09:22 PM
kspilkinton's Avatar
kspilkinton kspilkinton is offline
97-03 250LD/7700 Guru
kspilkinton has a very good reputation on FTE. kspilkinton has a very good reputation on FTE. kspilkinton has a very good reputation on FTE. kspilkinton has a very good reputation on FTE.
I looked at engine bay pics from the online versions of several magazines, as well as any specs I could find, and all that information I saw on 4.6 Cobra engines actually had "5W-XX"...
I was trying to justify the comment made by ford_man_of_vass about 15W in a Cobra engine, but what I found only made me think that a 5W base was the factory approved oil for Cobras. Why they would ship them other wise has me confused?
Anyway, I was going with the aluminum block and forged pistons over a cast iron block and hypereutectic pistons as the reason for the 15W, but since Ford doesn't build the Cobra engines with aluminum blocks anymore, that kinda throws that theory.
One of the reasons for the 5W-20 or 30 was the Tritons use hypereutectic pistons, and with a very tight tolerance... you kinda need the thinner oil.
For those that don't know, I pulled this definition from some on-line Wikipedia type joint:
Hypereutectic pistons are castpistons made from aluminum with over 16% silicon content for strength and durability. The term 'hypereutectic' comes from eutectic.
Special melting processes are necessary to ‘super-saturate’ the aluminum with additional silicon content. Special molds, casting and cooling techniques are required to obtain finely and uniformly dispersed silicon particles throughout the material.
These newer pistons are very hard, thus brittle. They have proven to be un-forgiving with engine knocking. For this reason they are great in naturally-aspirated engines, but should never be used with 'nitrous', super- or turbochargers. Generally speaking, forged pistons are a better choice for high boost.
Hypereutectic pistons are used in some original equipment engines. They are favored because of reduced scuffing, improved power, fuel economy and emissions. The reduced thermal expansion rate allows the piston to be run with reduced clearance.
The reduced emissions is the key reason Ford uses these pistons. The Hypereutectic pistons and the reduced clearences that they allow is the reason Ford uses 5W-20 today. The 5W-30 is perfectly acceptable if the truck calls for it. I'm not sure if tolerences in these engines became a slight bit "tighter" as the availability of 5W-20 became greater. If forged pistons were used, then 15W would be an understandable, although odd, alternative. Using the 15W in these engines would not be an engine life extending act.
-Kerry
  #64 (permalink)
Old 01-24-2006, 09:29 PM
[quote=kspilkinton]I looked at engine bay pics from the online versions of several magazines, as well as any specs I could find, and all that information I saw on 4.6 Cobra engines actually had "5W-XX"...
I would have 2 agree. No such mention of 15W in my Cobra
  #65 (permalink)
Old 01-25-2006, 12:38 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog has a great reputation on FTE. ford390gashog has a great reputation on FTE. ford390gashog has a great reputation on FTE. ford390gashog has a great reputation on FTE.
ford fills the cobra with 5w20. you can read the ford publication.
  #66 (permalink)
Old 02-19-2006, 09:53 PM
gysnst2 gysnst2 is offline
gysnst2 is starting off with a positive reputation.
im running 5w20 amsoil in my 4.6 04 heritage 24000 miles on my 4 oilchange and is comming out prety clean omost looks like new oil is draining out the oil pan.
  #67 (permalink)
Old 02-25-2006, 10:42 PM
blueknight44 blueknight44 is offline
blueknight44 is starting off with a positive reputation.
2003 4.6L 5w-20 Mobil 1 full syn 9,000 miles, great engine.
1986 4.9L new long block 10W-30 Mobil 1 full syn 200 miles, ran great today,ran 180 miles.
1991 460 cu 10W-30 Mobile 1 full syn, 68,000 miles, great engine.
1998 Kia 4cyl 1.9L DOHC 10W-30 Mobil 1 full syn, 67,000 miles,great engine.
  #68 (permalink)
Old 02-27-2006, 04:39 PM
pronstar pronstar is offline
pronstar is starting off with a positive reputation.
M1 10W-30 in my blown 5.4L
__________________
97 Expy XLT, 5.4L, 2WD | Intercooled Procharger| 10.5 psi | Full fuel system mods | 4.10 LSD | Tuned by Swanson Performance
  #69 (permalink)
Old 02-27-2006, 08:18 PM
johntucker09's Avatar
johntucker09 johntucker09 is offline
johntucker09 is gaining momentum as a positive member of FTE.
past the second oil change...
MC 5/20 and OE Motorcraft Filter...
__________________
2005 Ford F150 SuperCrew 4.6L - She's My One and Only...
A Member of the Texas Chapter - 2nd Place - Show 'N Shine - Gasoline Class
http://www.ford-trucks.com/user_gall...id=166101&.jpg
  #70 (permalink)
Old 05-21-2009, 06:46 PM
crewcab77's Avatar
crewcab77 crewcab77 is offline
crewcab77 is starting off with a positive reputation.
Quote:
Originally Posted by greenego View Post
I've been using 15w50 Mobil One in my 5.4 since it was new and it now has 48000 miles on it with no problems.
I don't think it will hurt at all. Where i work we have 5 superdutys from 99 to 2008 all of them have 5.4 in them. They run 15w40 in them as soon as the warranty was out. 4 of the have over 100,000 miles do not take a drop between oil changes no cold engine knock motors are way quieter then mine which next oil change i will be running 15w40. The 2008 is still under warranty but as soon as its done 15w40 will be put in that. They run 15w40 in all the crown vic cop cars also. This weight oil is run year around and i live in pa where it does get cold here from time to time. Just my 2 cents.
  #71 (permalink)
Old 05-22-2009, 11:29 AM
racerx6466 racerx6466 is offline
racerx6466 is starting off with a positive reputation.
5w-30 Valvoline Durablend with 1 quart Lucas oil treatment in my 99 4.6 F-150. Almost at 200,000
__________________
-2002 Ford Excursion Limited V-10 4x4 -Lifted with Bilstein 5100's and BFG All Terrains
-1999 Ford F-150 XLT 4.6 2WD -Hyperteched with K&N and Flowmaster exhaust -JBA Shorty Stainless Headers
-4.56's with Eaton Locker and Superior Axles
-Camburg Front Suspension -Deaver Leaf springs in the rear -Bilstein 5100's
  #72 (permalink)
Old 05-24-2009, 11:07 AM
Black03Screw Black03Screw is offline
Black03Screw is starting off with a positive reputation.
2003 Supercrew FX4 - 5.4L- Amsoil 5W-30. Have 106,000 miles on the truck and still running strong.
  #73 (permalink)
Old 05-25-2009, 11:42 AM
pepper32 pepper32 is offline
pepper32 is starting off with a positive reputation.
pennzoil 5w20 with motorcraft 820s filter.
  #74 (permalink)
Old 07-03-2009, 02:02 PM
Aquageist Aquageist is offline
Aquageist is starting off with a positive reputation.
Wtf
2000 f350 5.4 110k....Factory sticker under hood recommends motorcraft 5w30 but finding it in gallon jugs is impossible. All local parts and dept stores carry gallon jugs of 5w20 but only quarts of 5w30 both synth. Buying by the quart is significantly more expensive.
  #75 (permalink)
Old 08-28-2009, 06:32 PM
lilman320's Avatar
lilman320 lilman320 is offline
lilman320 is starting off with a positive reputation.
Motorcraft 5w-20 with the Motorcraft filter to keep it clean...
__________________
'99 F-150 Lariat 4x4 Very Nice!!!
"Speed kills, drive a Chevy and live forever."
Tags
04 , 2000 , 2003 , 54 , 54l , 5w30 , f350 , ford , high , oil , performance , put , triton , type , weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
