Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #46 (permalink)
Old 12-20-2005, 08:39 PM
kspilkinton's Avatar
kspilkinton kspilkinton is offline
97-03 250LD/7700 Guru
kspilkinton has a very good reputation on FTE. kspilkinton has a very good reputation on FTE. kspilkinton has a very good reputation on FTE. kspilkinton has a very good reputation on FTE.
Isn't 5W-20 more expensive too? Another money making tool?
-Kerry
  #47 (permalink)
Old 12-21-2005, 02:55 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog has a great reputation on FTE. ford390gashog has a great reputation on FTE. ford390gashog has a great reputation on FTE. ford390gashog has a great reputation on FTE.
uhhhhhhhhhhhhh NO!
5w20 is the same price , sometimes cheaper. you can get 5w20 for between 1.30 and 2.20.
  #48 (permalink)
Old 12-21-2005, 10:41 AM
03redstx 03redstx is offline
03redstx is starting off with a positive reputation.
Whatever the dealer is using for the next 2 oil changes, then 5W30 Amsoil and a Napa Gold Oil Filter
  #49 (permalink)
Old 12-21-2005, 09:34 PM
Quote:
Originally Posted by ford390gashog
uhhhhhhhhhhhhh NO!
Another flashback to my dad's truck... he has an '02 S'crew. At the time he bought it new and for many months thereafter his complaint was the cost of the oil (he's toned down since, should have guessed the price dropped). The only Motorcraft oil at the dealer (he gets his vehicles serviced at the dealer when they're under warranty... harder for them to claim it was his fault ) was the semi-synth 5W20 and it was more expensive than the 5W30 dino... being semi-synth will do that. I see from a quick search that the prices for 5W20 and 5W30 are the same. Perhaps as more vehicles demand a product, then more companies make it... supply and demand, eh?
-Kerry
  #50 (permalink)
Old 12-29-2005, 09:28 AM
green 1969 f100 green 1969 f100 is offline
green 1969 f100 is starting off with a positive reputation.
Question
I would like your opinion. My neighbor has a 1993 Lincoln with a 4.6 engine which he purchased 3years ago from an estate sale with no maintenance history and 75000 miles. This engine has consumed oil since he bought it and has become worse and now has 105000 miles. He has tried oils from 5w20 to 10w40 and it now consumes a quart per 500 miles. The pcv hose and valve have been replaced and there is no sign of exhaust smoke or oil leakage. I think Rotella 10w30 may help. I welcome your opinion.
__________________
1969 F100 360 C6
1995 F150 5.0 E4OD (Previous)
2000 F150 Super cab 4.6
2003 Accord 2.4
  #51 (permalink)
Old 12-29-2005, 01:49 PM
These modular motors have a history of eating oil... there are several threads in this forum and others where people will go through a quart or more per oil change. My recommendation based on this is to follow the under hood specs... in this case it should be 5W30. While a 10W base oil will be thicker on start-up, it may actually cause more wear and more oil consumption because of slower startup flow characteristics will wear the rings. In the long run, it's better to follow manufacturers specs with these motors.
-Kerry
  #52 (permalink)
Old 12-29-2005, 03:39 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of
Green, the biggest offender on the early engines like the 93 is failing valve guide seals. This causes them to burn oil. I would use no thicker than 5w30 due to the valvetrain needing oil quickly on start-ups.
Kerry, Walmart has Motorcraft oil 5w20 Semi-Synthetic for about $1.79 a qt. I always buy mine there. Their Motorcraft filters are cheaper too.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #53 (permalink)
Old 12-29-2005, 05:00 PM
KICK KICK is offline
KICK is starting off with a positive reputation.
5w30 Mobil 1 and motorcraft filters.
105k miles.
main reason FOMOCO specs 5w20 was it helps improve their C.A.F.E rating a small percentage.
In a hot climate I suspect you could get away with 20w50 regarding cold startups and lubrication to the top end but why chance it.
  #54 (permalink)
Old 12-29-2005, 08:07 PM
Thanks for the advice. Since I am now doing the oil changes on the Lincoln, It will be getting Motorcraft 5w30 oil and FL820S filter and checking the oil level more often.
__________________
1969 F100 360 C6
2003 Accord 2.4
  #55 (permalink)
Old 12-29-2005, 08:23 PM
LxMan1's Avatar
That's the best you can do without reworking the heads
__________________
88 5.0 LX Mustang
63 F100 351W/C6
  #56 (permalink)
Old 12-29-2005, 08:59 PM
The Wally World here never went back to stocking the Motorcraft brand, I have one of the last FL-820-S they sold back in April... that's the reason I use the old dino Mobil.
-Kerry
  #57 (permalink)
Old 12-29-2005, 09:00 PM
LxMan1's Avatar
Bummer, mine quit for a bit, but then brought it back
__________________
88 5.0 LX Mustang
63 F100 351W/C6
  #58 (permalink)
Old 12-29-2005, 11:15 PM
whimsey whimsey is offline
whimsey is starting off with a positive reputation.
The 2 Wally Worlds near me in NW NJ have Motorcraft 5W-20 for $1.98/qt. But they rarely have any in stock. I still have 1 1/2 cases left over that I bought back in March for $1.52/qt when they were "closing out" the Motorcraft line at Wally World plus about 8 FL820S for $2.97 . This is good for a minimum for 15,000 miles for me.
Whimsey
  #59 (permalink)
Old 01-22-2006, 04:38 PM
ford_man_of_vass ford_man_of_vass is offline
ford_man_of_vass is starting off with a positive reputation.
I want to tell the guys that think that 15W-50 or any 15W-XX's is to thick for a modular, your correct and wrong. It is to thick if your starting the engine at zero degrees or something. It would and is quite alright if it is warm out. A matter of fact if it is to thick as a few said, and was more less saying if you use it in a modular it will garnade in a short order. Why is it then that Ford used Mobil 1 15W-50, yes 15W-50 as factury fill in the modular used in the cobra mustangs.
  #60 (permalink)
Old 01-23-2006, 09:27 PM
What type of pistons does the 4.6 DOHC Cobra engine run, and what's the block made out of? This might have something to do with the weight of the oil.
-Kerry
Tags
04 , 2000 , 2003 , 54 , 54l , 5w30 , f350 , ford , high , oil , performance , put , triton , type , weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
