Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #31 (permalink)
Old 10-05-2005, 02:45 PM
FortyFords's Avatar
FortyFords FortyFords is offline
FortyFords is gaining momentum as a positive member of FTE.
5w30 all yr
50,000 no problems
Rich
__________________
" All levers like real trucks should be!" "Cool enough for me!"
" BSEG CLUB" 10 Strokin and 4 Smokin!
  #32 (permalink)
Old 10-05-2005, 03:52 PM
Firemut30 Firemut30 is offline
Firemut30 is starting off with a positive reputation.
Been using 5w20, switched to royal purple($$$) 10w30 once, couldn't talk myself into leaving it in for 7000 miles like they say you can so I switched back! I do think I will switch to mobil 1, have had good luck with it in the past.
__________________
'06 Screw,AEM Bruteforce air intake,SIDO exhaust
Chrome taillights,Chrome bed rails,Edge Evo
Carriage Works Billet Grille,2" lowering shackles,
LiquidMetal Lithium6 wheels with Kuhmo 275/55/20's
2-Infinity Kappa's,Infinity Basslink W/4sc amp
JVC KW-AVX800
  #33 (permalink)
Old 11-07-2005, 07:59 AM
young-g-ma young-g-ma is offline
young-g-ma is starting off with a positive reputation.
pen. 10W30 in 97 F-10 with 230,000 miles
  #34 (permalink)
Old 11-07-2005, 04:28 PM
xtrford xtrford is offline
xtrford is gaining momentum as a positive member of FTE.
Switched to Mobil1 0w20 for the winter, can get a tad cold up here north of the border, otherwise its 5w30 synthetic for the hotter months and nothing but motorcraft filters.
  #35 (permalink)
Old 11-11-2005, 02:10 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog has a great reputation on FTE. ford390gashog has a great reputation on FTE. ford390gashog has a great reputation on FTE. ford390gashog has a great reputation on FTE.
xtr,
why not use the 0w20 year round up there?
  #36 (permalink)
Old 11-12-2005, 04:19 PM
I think I will now, same price as the 5w30 synthetic, and the it specifies right on the jug that it is recommended for Fords that require 5w20.
  #37 (permalink)
Old 11-12-2005, 08:56 PM
gdawghereiam gdawghereiam is offline
gdawghereiam is starting off with a positive reputation.
Cool
have a 70250a/t2wd and a 82350a/t2wd.the 70 has 350,000-2nd engine,the 82 has 243,000-org. engine.valvoline 30wt 4 both.
  #38 (permalink)
Old 11-15-2005, 02:13 PM
aztec12 aztec12 is offline
aztec12 is starting off with a positive reputation.
5w30 in my 98 f150 4.6 with 98k on it.
  #39 (permalink)
Old 12-15-2005, 11:21 AM
Board627 Board627 is offline
Board627 is starting off with a positive reputation.
10w30 in 99 4.6 88k on it
  #40 (permalink)
Old 12-15-2005, 09:26 PM
kspilkinton's Avatar
kspilkinton kspilkinton is offline
97-03 250LD/7700 Guru
kspilkinton has a very good reputation on FTE. kspilkinton has a very good reputation on FTE. kspilkinton has a very good reputation on FTE. kspilkinton has a very good reputation on FTE.
I use 5W30 Mobil Dino and the Motorcraft FL-820S filter
The mods up to and including '01 were 5W-30, those built '02 and newer are the 5W-20 motors... for warranty requirements. Less and less '01s and older are under warranty anymore.
Use what you feel comfortable with, but if your motor is under warranty be very careful your oil meets the manufacturers requirements for viscosity. Ford figures out you've broken the engine do to the wrong oil (and that'll be the first thing they check - R&D loves this) and you can kiss your warranty rights goodbye.
-Kerry
  #41 (permalink)
Old 12-16-2005, 09:26 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of
My 01 calls for 5W-20 so maybe 97-2000 call for 5w-30.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #42 (permalink)
Old 12-16-2005, 11:39 PM
Thanks for the catch, Jimmy. I messed up, got to thinking about my dad's truck, then stuck my foot in my mouth.
For '97-'00 F-series Tritons, Ford requires 5W30 if under warranty
For '01 and newer F-series Tritons, Ford requires 5W-20 for warranty validation.
-Kerry
  #43 (permalink)
Old 12-17-2005, 08:00 PM
LxMan1's Avatar
I wasn't sure on the changeover year. I hope that foot didn't tase too bad!!
I have had no problems with the 5w20 Motorcraft oil and filter after 57,000 miles. It uses no oil between changes and the inside is very clean. I tow about 7,000lbs at times in 90+ degree weather with no signs of oil breakdown.
I think that these engines will run forever if properly maintained.
My sister in-law has a 93 Mark VIII with the DOHC 4.6L with about 190,000 miles and it runs like a scaulded dog. I hope my 5.4L runs at least as long. I'll probably have my 01 forever.
__________________
88 5.0 LX Mustang
63 F100 351W/C6
  #44 (permalink)
Old 12-18-2005, 02:09 PM
I don't know if the 4.2 V-6 ever changed to 5w-20...
-Kerry
  #45 (permalink)
Old 12-20-2005, 01:24 AM
LxMan1's Avatar
Probably, I believe that my Dad's 03 Taurus 3.0 calls for 5W-20 and it's an OHV engine like the 4.2L.
__________________
88 5.0 LX Mustang
63 F100 351W/C6
Tags
04 , 2000 , 2003 , 54 , 54l , 5w30 , f350 , ford , high , oil , performance , put , triton , type , weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
