Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 08-19-2005, 05:54 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog has a great reputation on FTE. ford390gashog has a great reputation on FTE. ford390gashog has a great reputation on FTE. ford390gashog has a great reputation on FTE.
whats the point of using a 50w in the engine? its not going to give you added protection over 5w20. take a look over at bitog and look at some of the mod engine test results all of them show higher wear numbers when you go over 10w30 and they all show very nice looking numbers when you use 5w20.
__________________
If it doesn't fit, FORCE it.
If it breaks, well, it needed replacing anyway.
  #17 (permalink)
Old 08-20-2005, 07:45 PM
RH F-350 RH F-350 is offline
RH F-350 is starting off with a positive reputation.
Motorcraft 5w-30 oil and filter
  #18 (permalink)
Old 08-20-2005, 11:44 PM
BubbaP BubbaP is offline
BubbaP is starting off with a positive reputation.
1999 5.4 Expedition. 5w30 since we bought it at 50,000 miles about 2 1/2 years age. About 80,000 on it now. Motorcraft 820S filters. Uses about 1/2 quart in 2000 miles.
  #19 (permalink)
Old 08-21-2005, 11:03 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of
15W as a base stock is a bit thick for start-ups on a modular engine. You want oil to the top of the engine as soon as possible due to the overhead camshafts and such.
Oil is designed by using a base stock number say 5W for instance and then has additives to make it a certain thickness when hot = 20.
So 5w20 flows like 5wt when cold and 20wt when hot.
15W40 is thicker when cold 15wt and will not reach the top of the engine as fast when cold and 40wt when hot is not required.
I have towed 7000lbs in 98degree weather with the a/c on and have never used any oil between changes and have had no adverse effects from the 5w20 in 54,000 miles.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #20 (permalink)
Old 08-24-2005, 10:54 AM
bryyce62's Avatar
bryyce62 bryyce62 is offline
<------My Stinky Girl
bryyce62 has a very good reputation on FTE. bryyce62 has a very good reputation on FTE. bryyce62 has a very good reputation on FTE. bryyce62 has a very good reputation on FTE.
Motorcraft 5-20 since new. 51K today, no problems. (knock on wood)
gw
__________________
'03 Lariat CC 4X4, FT valve body, Y-pipe mod, Bilsteins, 500Wx5, Stealthbox, FIPK, Magnaflo, '08 diff cover
  #21 (permalink)
Old 08-24-2005, 04:29 PM
nasa-hvac nasa-hvac is offline
nasa-hvac is starting off with a positive reputation.
havoline 5w-30 with fram tough guard filter...181k
  #22 (permalink)
Old 09-02-2005, 04:43 PM
350z 350z is offline
350z is starting off with a positive reputation.
Thumbs up
Motorcraft 5-20w/fl820s filter -10k miles.
__________________
04 F350 5.4l auto 4x4 sc sb lariat,buckets,4.10LS, plow,camper/overload springs/rear sway bar,FX4,pwr pedals&slider,backup sensors,heated/lighted mirrors,cab lights,Gibson stainless exhaust,FTVB,6"superlift w/diesel
springs,35's,bilstein5100's,alarm/remote/pager,undercover,spd y pipe.
  #23 (permalink)
Old 09-06-2005, 06:59 PM
Thomascoupling's Avatar
Thomascoupling Thomascoupling is offline
Thomascoupling is starting off with a positive reputation.
Thumbs up
5w-20 motorcraft
__________________
2001 SD F-250 XLT, 5.4 Eng., 4x4, Supercab.
http://www.ford-trucks.com/user_gall...oid=82969&.jpg
  #24 (permalink)
Old 09-06-2005, 09:01 PM
ATC Crazy's Avatar
ATC Crazy ATC Crazy is offline
ATC Crazy has a good reputation on FTE. ATC Crazy has a good reputation on FTE. ATC Crazy has a good reputation on FTE.
Origional owner ran 10w40 (or was it 10w30?) since he bought it new. I havent had it long enough to do an oil change.
__________________
-2006 Dodge Ram 3500 ThunderRoad ed. CTD, 6-spd, and 4" straight pipe!
-1985 Toyota Pickup
-1978 F150 - 466ci/4-spd/4" lift/35's
-1978 Bronco - Parts
  #25 (permalink)
Old 09-11-2005, 11:18 AM
351PWR 351PWR is offline
351PWR is starting off with a positive reputation.
A good Ford mechanic that I know recommended using the Motorcraft 5W20 synthetic all year for the 4.6
  #26 (permalink)
Old 09-11-2005, 01:48 PM
fordiesel69 fordiesel69 is offline
fordiesel69 is starting off with a positive reputation.
Ford390gashog,
Do you have a link pointing to the wear tests between the different oils? You mentioned it in your other post.
__________________
My Rigs:
86' F-250 XLT Lariat,6.9 Diesel, Extended Cab, 4x4, 4.10's, 8'bed, Push Button Glowplugs, etc...
99' Crown Vic Police Interceptor (P71) w/Steet apperance package
  #27 (permalink)
Old 09-11-2005, 06:42 PM
2000BLK54 2000BLK54 is offline
2000BLK54 is starting off with a positive reputation.
Mobil 1 5w-30 and FL-820S filters since new. No problems or oil consumption.
__________________
2000 F-150
SuperCab 5.4L, Flareside
S&B, Flowmaster SI/DO, T. Perfomance Dual Electric Fan Kit, ATI ProCharger P-1SC (12 psi), Snow Methanol injection, Jet-Hot full length headers, offroad exhaust
www.cardomain.com/id/2000blk54
  #28 (permalink)
Old 09-11-2005, 08:37 PM
GRB1 GRB1 is offline
GRB1 is starting off with a positive reputation.
Motorcraft 5W20 with FL-820s filters only 18,000 miles to date.
  #29 (permalink)
Old 09-20-2005, 10:11 PM
92f150I6's Avatar
92f150I6 92f150I6 is offline
92f150I6 is starting off with a positive reputation.
Just switched to Mobil1 5W30, and the MC 5W20 looked nasty when I changed it.
__________________
2003 F250 SD 4X4 5.4L 4:10 Arizona Beige
1987 Mustang GT
09 Challenger RT
A bunch of motorcycles, other cars, and a Quad.
  #30 (permalink)
Old 10-04-2005, 10:15 PM
white line white line is offline
white line is starting off with a positive reputation.
i think location has something to do with it
i live in south texas and i have always used 20/50 in all my trucks doesnt get to cold here. in colorado for 7 winters sure we used the lower viscosity. havent heard that this is bad .
Tags
04 , 2000 , 2003 , 54 , 54l , 5w30 , f350 , ford , high , oil , performance , put , triton , type , weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
