1995 Dual Tank - Fuel Pump Issue?
I know this sounds a little obvious...but don't want to waste my time droppiing the fuel tanks if anyone has had this problem before. I got a 1995 F150 5.0 L w/ dual tanks with only 93K miles. Started getting a bad miss/stutter when under load running on front tank. Everything runs fine on the rear tank. I also get a little static on the radio when running on front tank. I'm getting ready to drop the tank (both) and change fuel pump. Anybody else got any ideas to help save my weekend!! Also...is this more than a weekend job...I need the truck for work on Monday!
Thanks
Thanks
Don't laugh...I have not even crawled under the truck to look at the tanks yet.... I just assumed it was one big tank with a baffle in the middle. I figured it was not much more work to change both pumps. I guess from your thread that there are actually two tanks (i.e. I can drop one tank at a time). Looks like I'll just replace the front pump and wait for the rear one to fail next year!
Thanks for the help.
on
1 Post
there are two ways to change pumps 1 is to drop the tank the other is to lift the bed. being that the pump is mounted thru the top of the tank. I found that it was far easier to lift the bed after dropping one tank in my pops 87 with duals all the years of dirt and road grim falling on your head and into your face..after replacing the number one tank fuel pump the number two went out..so second time around I lift the bed drove the truck out from under neither it change the pump and it allowed me to get a better look at every thing else in the back end also change the fuel filter you will need a special tool to compress the spring in the fule line you can pick it up at napa for about ten
Bed bolts can be a PITA if they're rusty... But it might be a better option if you are doing both pumps.
Dropping the tank isn't too bad. While the front tank is out you'll have much better access to the fuel filter. Why Ford didn't put it 6 inches further forward I'll never figure out.
I'm thinking about it myself....
I agree...Unless the bed is coming off, the rear tank is a toal PITFA to drop solo...
wevie
08-26-2021 07:02 PM
V8SHO
19
04-24-2017 05:36 PM
