check engine OBD code PO401
Sorry. 2000 3.0 flex fuel.
I found it between my two replies. Blew some carb cleaner through the tubes on the sensor and got some crud, including what looked like a hairball, to come back out at me.
I had to replace one of the rubber tubes a while back due to a hole and suspect that hair got sucked via the hole.
BTW, which one of rubber hoses goes where on the EGR tube?
Thanks
Bill
Thanks
Bill
Here is a summary of the Ford EGR/DPFE system that might help:
Ford DPFE/EGR System Summary
Well, I cleaned everything, made sure the hoses were correct and the code came back. Replaced the DPFE and still got the code. Replaced the EGR valve and have not gotten any CEL...yet.
But, now I experience hesitation and stumbling on acceleration. When cruising with the throttle just cracked open the truck "bucks". Sounds like bad EGR valve. Any ideas?
Thanks
Bill
Thanks
Bill
Wow, never heard that before. So you're basically discharging all of the circuitry. Hmmm.
Thanks!
Thanks!
