Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 08-13-2005, 09:34 PM
edub32's Avatar
edub32 is starting off with a positive reputation.
Best Value Downpipe
Hey guys, about to spend more funds on exhaust...I tried searching for that cheap downpipe thread but nothing came up..deleted? Anywho, I'm going to first start off the system with a 4" downpipe. I really like the Hog Performance stainless 4" downpipe from motorhaven. ( http://motorhaven.com/home.php?cat=303) third item down. It's only $132.99 + shipping. I thought that was a really good deal. Do you guys have any other downpipes that you think are pretty good priced or do you think this is the best value?
__________________
2001 F350 7.3 SCLB 4x4 Off-Road SRW
- DP Tuner, Tymar intake, 35" BFG Mudders, Superlift 6" lift, DiPricol 3 gauge Pillar, 4" SS DP to 5" sidepipe to 6" Chrome tip, WW, Panasonic Deck with 4xInfinity References, Overboost Elim., CCV
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 08-14-2005, 10:38 PM
edub32's Avatar
bump..........................................
__________________
  #3 (permalink)
Old 08-15-2005, 03:49 AM
psdpower's Avatar
psdpower is starting off with a positive reputation.
I am happy with my ITP 4", it's not stainless, and I think it was right around $100.00. Check out www.innovativetruckproducts.com .
__________________
Early 99 F250 XLT 4X4 6-spd ISSPRO gauges, 2.5 inch lift, 315/75/16 Cooper A/Ts, Clamp, Tymar, 4 inch ITP dp, 4 inch straight pipe, CCV mod, DI BRV, boost tube, EBPV brake, dynoed 238 hp, 588 lb-ft
  #4 (permalink)
Old 08-15-2005, 03:53 AM
psdpower's Avatar
Can't seem to get the site to come up, I haven't bought anything from them in a while, so that mught not be the right address.
__________________
  #5 (permalink)
Old 08-15-2005, 11:54 AM
edub32's Avatar
Thanks PSDpower, that's exactly what I'm looking for; a 4" aluminized for $100 or less
__________________
  #6 (permalink)
Old 08-15-2005, 12:06 PM
edub32's Avatar
Ah, I think I found the site....http://www.itpdiesel.com/store.php?c...on=show_detail
This one is t-409 stainless for $100
Thanks for showing me this site
__________________
  #7 (permalink)
Old 08-15-2005, 12:12 PM
strokin_it7.3's Avatar
Nonsupportive
strokin_it7.3 is a splendid one to beholdstrokin_it7.3 is a splendid one to beholdstrokin_it7.3 is a splendid one to beholdstrokin_it7.3 is a splendid one to beholdstrokin_it7.3 is a splendid one to beholdstrokin_it7.3 is a splendid one to beholdstrokin_it7.3 is a splendid one to behold
just make sure the downpipe you are buying will hook up freely to the rest of the exhaust system
__________________
02 F-350 with lotsa bling, some you see, some you don't.
Licensed 7.3 engine remover/installer
  #8 (permalink)
Old 08-15-2005, 12:22 PM
edub32's Avatar
What exactly do you mean strokin_it7.3?
What I need is a 4" downpipe that goes from a 4" OD to a 4" ID. I think the Hog performance one does that. I don't think the ITP one does unfortunately.
Do you guys think that $34 is a little high for shipping on a downpipe?
__________________
  #9 (permalink)
Old 08-15-2005, 09:12 PM
psdpower's Avatar
That is the one I got, I was sure it was aluminized, but I guess not. I built the rest of my exhaust after the DP, so I had no fitment problems. If you are using one company's dp, with another company's exhaust, they may not meet up exactly right. You may either have to cut a bit off the end of the dp or add a bit to it, to get the two pipes connected.
__________________
  #10 (permalink)
Old 08-15-2005, 09:16 PM
edub32's Avatar
Well, I'm doing the 4" downpipe and then custom back from that.
__________________
  #11 (permalink)
Old 08-15-2005, 11:59 PM
psdpower's Avatar
Then you will be fine. One other thing to look out for with that dp is it gets a little tight between the starter and the leafspring shackle. With stock shackles it should be fine but with the leveling kit I have I had to be very careful to avoid rubbing on the shackle or starter.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
