Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-13-2005, 01:22 AM
pcmenten pcmenten is offline
Garage is empty, add now
pcmenten is starting off with a positive reputation.
Fuel economy tip - acetone in fuel
I don't know where I heard it first, but I've recently been putting a little acetone in my fuel tanks to help with economy. It seems to work.
What I've heard is that the acetone helps with fuel vaporization. But I also think it's been cleaning the injectors. My wife's Jeep with the 5.2l V8 has been running much smoother since I've run three tanks of gas with a little acetone. Fuel economy has picked up from about 15.5 to 17 or more in town, and from 21 to 23 mph on the highway.
I'm leery of using it for stop-and-go driving. I supect that it's hard on rubber and plastic, and it might overload the vapor canister system because of the increased vaporization of fuel. But if you're going to be taking a trip and burning though a few tanks of gas, I recommend getting a gallon of acetone, and adding about 4 ounces per 10 gallons of gas.
__________________
Best regards,
Paul Menten
  #2 (permalink)
Old 08-13-2005, 06:21 PM
zs_tx zs_tx is offline
zs_tx is starting off with a positive reputation.
anyone ever hear of anything like this before? is this kinda like adding fuel cleaner?
  #3 (permalink)
Old 08-13-2005, 09:59 PM
Flash Flash is offline
Flash is gaining momentum as a positive member of FTE.
Any of the solvents in the Keytone family will be a plasticizer meaning that it can destroy/dissolve plastics. It is a 150 octane rated fluid and is hot meaning that it vaporizes rapidly. There is no real science behind it to say that it works. B-12 Chemtool uses it a a carrier fluid. I would excerise caution in putting it in your tank as it also is a great paint remover.
  #4 (permalink)
Old 08-14-2005, 01:29 AM
If a gallon of gas is 128 ounces, 10 gallon is 1280 ounces, and you're adding 4 ounces of acetone, that's about .3%; 3/10ths of one percent. What I hear is that it lowers the pressure of vaporization. The fuel vaporizes at a lower temperature.
In a closed-loop electronic fuel injection system, better vaporization means 'leaner' mixtures. I quote the word 'leaner' because the oxygen sensor will adjust the mixture to deliver less fuel, but that's because less fuel goes out the tailpipe. The air/fuel mixture is lower because it takes less fuel to use up all the oxygen in the combustion chamber. Less carbon on the valves, less on the piston tops, cooler running cats.
I've also heard that the main ingredient in fuel additives is acetone. I think that at 3/10ths of 1% level, it's worth doing, especially on trips.
__________________
Best regards,
Paul Menten
  #5 (permalink)
Old 08-14-2005, 01:59 AM
hmmmm so adding b-12 chemtool is pretty much the same thing? or no? just wondering cause i take long trips pretty regular.... usually around 1400 miles one way - so even a couple extra miles per gallon will make a noticable difference.
  #6 (permalink)
Old 08-14-2005, 03:38 AM
RKK's Avatar
RKK RKK is offline
RKK is starting off with a positive reputation.
It also affects brain cells and can make you go bug-eyed!
  #7 (permalink)
Old 08-14-2005, 04:56 AM
so no more sniffing to check for "purity"?
  #8 (permalink)
Old 08-15-2005, 12:42 AM
Quote:
Well, the MSDS says that Berryman B-12 Chemtool Summer Diesel Treatment is 85% kerosene(CAS 8008-20-6), and 15% other. Short answer, you'll have to do your own research to find that out.
__________________
Best regards,
Paul Menten
  #9 (permalink)
Old 08-15-2005, 09:03 AM
460429_freak's Avatar
460429_freak 460429_freak is offline
460429_freak is starting off with a positive reputation.
well on another board im on (for explorers) they say to mix 1 oz per 10 gallons one guy who has his explorer up to 30 mpg tried this and found out it up his milage by 1.5 mile per gallon..you have to play with the amount for your vehicle and they also said it takes up to 3 tanks for it to take affects..
__________________
Can't list my Ford's only allowed 300 letters.... to many to list
FORDS always look better when pulling a CHEVY
  #10 (permalink)
Old 08-25-2005, 04:32 PM
GBFD_EMS GBFD_EMS is offline
GBFD_EMS is starting off with a positive reputation.
i have just done some research on this myself and i have decided not to go ahead with this. Acetone can eat away fuel lines after a while. you might be saving your self right now but what happens when you have to get a new fuel line because the acetone ate it...?
  #11 (permalink)
Old 08-25-2005, 07:38 PM
Quote:
Everybody has to make up their own mind, but I've been using it for a while with no ill effects. I have seen it dissolve polycarbonate (clear plastic) measuring cups, but I not aware of problems with polychloroprene (neoprene aka fuel lines).
__________________
Best regards,
Paul Menten
  #12 (permalink)
Old 08-25-2005, 09:54 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
at one or two ounces per 10 gallons, is there even enough there to worry about doing damage to the seals?
__________________
Eric
'87 F150 302 ZF 5 speed 4x2
  #13 (permalink)
Old 08-26-2005, 05:31 PM
acetone can also do damage to engine pistons. so use this at your own risk
  #14 (permalink)
Old 08-26-2005, 11:01 PM
Oh, come on! I call bullcrap. Tell me how that happens. What's next, it eats cast iron?
Look up acetone in Wikipedia and you'll see that it's a naturally occurring substance. Your body makes it.
__________________
Best regards,
Paul Menten
  #15 (permalink)
Old 08-27-2005, 12:32 AM
keep throwing the junk into your truck and get back to me. im actually thinking about purchasing a diesel VW and going with bio diesel
Tags
acetone, economy, fuel, gallon, menten, paul, running, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
