issues with my 1999 f150
Old 08-31-2005, 10:02 AM
oldsw-31's Avatar
oldsw-31
oldsw-31 is offline
The trans is leaking fluild from what appears to be a intermediate housing between the trans and transfer case. upon inspection there was missing some bolts on the trans side of the housing. how hard is it to replace the gasket there. does anyone have a picture ? I hope the trans case is not cracked.
Old 08-31-2005, 11:43 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 08-31-2005, 12:34 PM
l-m tech's Avatar
l-m tech
l-m tech is offline
there should be 6 13 mm headed bolts that hold the transfer case to the trans.you could try starting with all the bolts tightened up and see if that stops the leak.pulling the transfer case is kinda pain in the rump.
Old 09-11-2005, 07:27 PM
oldsw-31's Avatar
oldsw-31
oldsw-31 is offline
well upon inspection the left upper most ear is broken off the transmission case and the bolt was still in there. far as the other bolts, upper right is broken just under the head of the bolt. same as the one on the left side middle . its missing a bolt on the lower left and the other 2 bolt are there but???? I was hoping I may be able to remove the transfer case and remove the broken bolts and replace the gasket and just use some sealer for now. and get some grade 8 bolts has any one else experianced this
this is on my 99 f150 extcab long bed truck
Old 09-12-2005, 08:31 AM
l-m tech's Avatar
l-m tech
l-m tech is offline
if you have it that far down replace the extention housing if it is broke.it only takes a few extra minutes.
Old 09-12-2005, 09:36 PM
oldsw-31's Avatar
oldsw-31
oldsw-31 is offline
the actuall ext housing is good. its the transmission thats broken.
i WAS able to locate a dealer overstock trans for 550.
Old 09-13-2005, 09:54 AM
l-m tech's Avatar
l-m tech
l-m tech is offline
glad to hear that.not very often a man can get a brake on something like that.
Old 09-14-2005, 07:01 PM
oldsw-31's Avatar
oldsw-31
oldsw-31 is offline
what type of ATF fluid does my truck take mercron or mercron 5 ?
Old 09-15-2005, 08:13 AM
l-m tech's Avatar
l-m tech
l-m tech is offline
if you pull the dipstick out it should tell you .
cjdm_1
04-22-2023 04:03 AM
squid1964
01-16-2005 09:58 AM
Quick Reply: issues with my 1999 f150
