NEED 302/ 332 HD Y-Block Crank or INFO - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 08-28-2014, 12:27 AM
Elgin Boy Elgin Boy is offline
Elgin Boy is starting off with a positive reputation.
Richardge,
Your more than likely right on about the 332 cam. I think that Crane will make one once one has all the other stuff sorted out for ones 368. It all sounds like money to me. I would love to bore and stroke my 368. I am not sure if the HD truck 4 barrel manifold had a much higher profile, than the stock 368. If I can get the parts I need now than I'll look into pistons and rods. The M335 intakes are way out there right now.
I have heard about the tri power set up but haven't seen any ever.
Thanks
I am looking to put it in my 53 Capri.
  #47
Old 08-28-2014, 07:09 AM
richardge richardge is offline
richardge is starting off with a positive reputation.
Don't have one>
  #48
Old 09-21-2014, 12:13 AM
1960fordf350's Avatar
1960fordf350 1960fordf350 is offline
1960fordf350 is starting off with a positive reputation.
I have an intake. I also have a 332 crank, loose. I also have a complete 332 engine with the holley carb on it. PM me
  #49
Old 09-21-2014, 03:34 PM
I'd PM if I could figure out how. How much do you want for the intake? Richard 517-898-0646
Wanted Elgin Boy Ford Truck Parts for Sale 0 10-10-2014 01:30 PM
1955 Ford F800 Big Job Power Steering mint51 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 08-06-2014 11:42 PM
1955 Ford F800 Power Steering Set Up mint51 1961 - 1966 F-100 & Larger F-Series Trucks 0 08-03-2014 08:54 AM
302 and 332 Y-Block captradiator Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 3 01-04-2006 06:55 PM
Retro Efficient Baby FE? bhabben FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 20 09-18-2003 05:01 AM
Tags
1957, 292, 302, 332, 5750174, block, closer, crank, crankshaft, engine, ford, hd, lincoln, number, towing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
