NEED 302/ 332 HD Y-Block Crank or INFO - Page 2 - Ford Truck Enthusiasts Forums
Old 12-09-2005, 09:09 PM
Tomc750 Tomc750 is online now
Tomc750 is gaining momentum as a positive member of FTE.
I have a 302 that ran well, I stole the 4bbl intake off it to put on a 332. The 332 has the same crank according to the parts book. I believe the crank should be ok as it had good oil pressure. I live in upstate NY though. There is probably one closer.
Old 04-23-2010, 10:20 PM
eratchetos eratchetos is offline
eratchetos is starting off with a positive reputation.
Thumbs up
Quote:
Originally Posted by prostocktom View Post
Hey Guys, I'm looking for a 302/332 HD Steel y-Block Truck Crankshaft used in late 50's early 60's HD Big Trucks . It is steel not iron and has 3.66 stroke. I need a good usable crank or If someone out there has the correct part number for this item that would be great also. For the guys out there who know what I'm working on I'm geting close to having the monster finished. Working on finishing the intake now. I also think that I'm going to make a blower intake for a 3-71/ 4-71 size blower. 455 inch blown Lincoln Y-block could be a really neat piece ????? Thanks Guys
I also need 302/332 steel crank for hd ford 1960-62 truck superceeding part# is C3TZ-6303-A I do not have original p/t # Please contact me if you have info on where I can get one!
Old 04-23-2010, 10:23 PM
302 /332 hd ford truck ram horn exhaust manifolds
Have rams horn manifolds for above engine also fits 279,317, 341, 368 Lincoln Y block 1952 - 1957 sell or trade!
Old 04-24-2010, 02:10 AM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is gaining momentum as a positive member of FTE.
This thread is 5 years old, but hope you find the part.
Old 04-24-2010, 08:59 AM
1960fordf350's Avatar
1960fordf350 1960fordf350 is offline
1960fordf350 is starting off with a positive reputation.
Tom
I've got your crank. I just junked a 332. I've had it checked by a friend and he says all it needs is polished. I've got the heads and cam too.
Old 04-24-2010, 09:10 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by eratchetos View Post
I also need 302/332 steel crank for hd ford 1960-62 truck superceeding part# is C3TZ-6303-A.
You do...now.
Welcome to FTE
C3TZ6303A replaced B8Q6303A fits 1958/63 302/332.
But...no Ford Dealer or obsolete part vendor has either one.
Try: Southern California Truck Wrecking (in business, same family owned since 1929) / 323-587-3144, ask for Marty / Open M-F closed weekends.
btw: When buying Ram's Horn exhaust manifolds, be aware there are three different types...they do NOT interchange!
Lincoln Y blocks / Ford Y Blocks / 1964/78 FT engines.
Old 04-24-2010, 09:14 AM
old uhaul old uhaul is offline
old uhaul is starting off with a positive reputation.
I have a complete low mileage lincoln 332 out of a 1956 F900 firetruck if anyone needs one.I am going to the F100 supernationals in may in tennessee
Old 04-24-2010, 09:19 AM
Uh...this year it's being held in Pigeon Forge NC ~ May 13-15. It was held in Knoxville 2008/2009.
I was there in 2008, t'was a long trip from CA to look for NOS parts for old rolling piles of misery.
Old 04-24-2010, 11:29 AM
Glad its back in pigeon forge,i had attended since 1989 but didnt go in 2008 and 2009.
Old 04-25-2010, 10:35 PM
how are you getting 455 cu in out of a y block lincoln 368= 4x3.66. stroker ? , From a Lincoln y block nut Eratchetos
Old 04-25-2010, 10:40 PM
Hey thanks Bill Will call them mon.AM ERATCHETOS
Old 04-26-2010, 04:49 PM
vbarker vbarker is offline
vbarker is gaining momentum as a positive member of FTE.
When did they move Pigeon Forge from Tennessee to North Carolina?
I guess I missed that one.
  #28
Old 04-26-2010, 07:06 PM
Quote:
Originally Posted by NumberDummy View Post
This year it's being held in Pigeon Forge NC
Quote:
Originally Posted by vbarker
When did they move Pigeon Forge from Tennesse to North Carolina?
I'm the one to blame for this error in geography, sorta.
A coupla weeks ago, I typed in the 1961/66 forum that the meet had moved to Pigeon Forge TN
Someone then chimed in and said...Pigeon Forge is in NC, just over the TN border.
Since I've never been there, I didn't check to see if this was correct.
  #29
Old 04-26-2010, 07:17 PM
Bill, You are forgiven.
Your wealth of knowledge and input definitely makes up for one minor mis-calculation.
Vern
  #30
Old 04-26-2010, 07:24 PM
Vern
The thread in question was something like this: "Who is going to the F100 SuperNationals?"
I chimed in and said I was going (I was there in 2008) and that the meet had moved from Knoxville to Pigeon Forge TN
Then someone corrected me...(in error, as you pointed out).
btw: I had to cancel my reservation, due to a health issue I had on the 16th of March.
Wanted Elgin Boy Ford Truck Parts for Sale 0 10-10-2014 01:30 PM
1955 Ford F800 Big Job Power Steering mint51 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 08-06-2014 11:42 PM
1955 Ford F800 Power Steering Set Up mint51 1961 - 1966 F-100 & Larger F-Series Trucks 0 08-03-2014 08:54 AM
302 and 332 Y-Block captradiator Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 3 01-04-2006 06:55 PM
Retro Efficient Baby FE? bhabben FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 20 09-18-2003 05:01 AM
Tags
1957, 292, 302, 332, 5750174, block, closer, crank, crankshaft, engine, ford, hd, lincoln, number, towing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
