Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 08-12-2005, 02:22 PM
gas_turbine_boy gas_turbine_boy is offline
gas_turbine_boy is starting off with a positive reputation.
Cool faulty rotors
I took my '04 Escape in for front brake work. It has 29,000 miles on it. The rotors needed to be replaced, as they were to thin to turn! I have a 86 F250 with 250,000 miles on it, and it has the original rotors! I need help in how to get Ford to pay for the rotors. Any suggestions will be appreciated.
__________________
2004 XLT "No Boundaries" Escape
  #2 (permalink)
Old 08-13-2005, 12:16 PM
Blackie60 Blackie60 is offline
Blackie60 is starting off with a positive reputation.
Sorry that you have to go thru like this and My 03 Escape of orginial rotors did thin out cuz it is cheap and soft metal from factory and I replaced it myself with aftermarket parts which is EBC brands and seem doing well this far and don't let the dealership replace it for you or you may end up in next 30,000 miles like this. So, wish you luck.
__________________
'03 F-250 XLT CC 6.0 Shortbed FX4
'03 Escape XLT 3.0 4X4
  #3 (permalink)
Old 08-14-2005, 03:29 PM
NewEnglandHerdsman's Avatar
NewEnglandHerdsman NewEnglandHerdsman is offline
Moderatee...
NewEnglandHerdsman has much to be proud of NewEnglandHerdsman has much to be proud of NewEnglandHerdsman has much to be proud of NewEnglandHerdsman has much to be proud of NewEnglandHerdsman has much to be proud of NewEnglandHerdsman has much to be proud of NewEnglandHerdsman has much to be proud of NewEnglandHerdsman has much to be proud of
Hey Blackie...
Did you have to do much disassembly to get the rotors off, or do they just pop off once the lugs nut and wheel have been removed?
TIA...
- jf
  #4 (permalink)
Old 08-14-2005, 03:35 PM
Not too much as it looks. Just take off the capiler and the bracket that hold the capiler and remove the lock washer from stud and the rotors will come off.
__________________
  #5 (permalink)
Old 08-14-2005, 05:54 PM
triton_2002's Avatar
triton_2002 triton_2002 is offline
triton_2002 is starting off with a positive reputation.
Unless they are rusted on, which happens alot, then you might have to knock them off with sledge and block of wood.
__________________
2002 F-150 Supercab 5.4 Triton V8
Arizona Biege
  #6 (permalink)
Old 08-16-2005, 12:25 PM
BlueOval5.0 BlueOval5.0 is offline
BlueOval5.0 is starting off with a positive reputation.
You would think Ford would have taken care of this issue by now. The rotor issue has been around since day 1. If you replace them with OEM parts, you will be replacing the rotors again shortly, possibly before the pads wear out!
__________________
2007 Ford Fusion SEL V6
1998 Ford Explorer XLT AWD 5.0 (Sold)
1990 Ford Mustang GT (Sold)
1993 Ford F-150 XLT Super Cab 5.0 (Sold)
1991 Ford Escort LX Hatch 1.9 (Sold)
  #7 (permalink)
Old 08-18-2005, 11:48 AM
bumpzter bumpzter is offline
bumpzter is starting off with a positive reputation.
Quote:
Toatally agree with that. Why are they not doing anything? Well known issue. Everybody, includingy the competition, knows about.
  #8 (permalink)
Old 08-18-2005, 05:50 PM
bananaboat bananaboat is offline
bananaboat is starting off with a positive reputation.
Because it's not a "safety" issue and most drivers take it back to the Ford dealer and pay $400+. Profit ahead of complaints! Same reason the V6 spark plugs on the rear bank are so hard to access. Though a DIYer can do it in less than 2 hours, it ain't like the old days of a 15 minute plug change.
FYI, I just hit mine lightly with a rubber mallet and they came off and I had 75k miles.
  #9 (permalink)
Old 08-18-2005, 09:12 PM
MazdaRangerGuy MazdaRangerGuy is offline
MazdaRangerGuy is starting off with a positive reputation.
The pads are actually designed to cut into the rotors as you stop... to keep the rotors true. The drawback is that they are throw-away rotors.. you have to replace them with just about every brake service. This is by design. (focuses are the same way)
You can search for aftermarket rotors (I wouldn't use them with ford pads.. use aftermarket pads) and they may hold up better... but don't be surprised if they tend to warp or make noise.
Good luck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
