Coil front suspension
Old 10-07-2002, 11:49 PM
elliott's Avatar
elliott
elliott is offline
If you can put a 79 F150 coil spring solid axle in a 80's F150, can you put the same 79 axle assy in a 79 F250? thanks, Elliott
Old 10-08-2002, 07:00 AM
tellico racing's Avatar
tellico racing
tellico racing is offline
You could put anything in if you can run a torch and a welder.
78 F150 4x4
429 CID
Dana 44 spooled Front,
9"Locked rear,
5:13 Gears
17/40/15 Gumbo monster mudders
18/39.5/15 Swamper Boggers
BIG,BAD,and UGLY.
Old 10-08-2002, 06:16 PM
elliott's Avatar
elliott
elliott is offline
Sorry. I guess I wasn't explicate enough. There is an article in the tech section that led me to beleive that the 79 4X4 F150 coil front end will fit into a 80's F150 with "minor" modifications. My question is; Will the 79 F150 4X4 front axles assy go into a 79 F250 with out "major" modifications. Hope this clarifies my orginal question a little more. Thanks, Elliott
Old 10-08-2002, 06:52 PM
mudder trucker's Avatar
mudder trucker
mudder trucker is offline
no its not going to work to easily, the f250 has leaf springs. mudder trucker.
Old 10-09-2002, 09:06 PM
elliott's Avatar
elliott
elliott is offline
I see I still neglected some info. The F250 is a 2 wheel drive with
the twin I beam suspension. Thanks, Elliott
Old 10-09-2002, 09:12 PM
Ford79's Avatar
Ford79
Ford79 is offline
elliott
04-05-2004 04:25 PM
elliott
09-18-2003 09:33 PM
elliott
03-07-2003 07:37 AM
elliott
12-03-2002 08:55 PM
Quick Reply: Coil front suspension
