Van Leaning to one side
Hi everyone and thank you all for your helpful suggestions in the past. I have an `89 E150 302 138" wheelbase. It is equipped with a wheelchair lift and has a power sliding door. It has the original rear leaf springs. It is leaning to the passenger side (probably from the weight of the lift). Took a body to tire measurement on both rears and there is approx a 2" difference in height. Would I be able to correct the 2" difference with a bolt on full length helper spring? Or do I need to have that spring replaced? Any other suggestions? Other than the leaning issue, the van rides and handles great.
Replace the Springs
After a good amount of time the spring on the left side will sag from the weight. A helper spring would be a waste of money. You could get set of spings from junk yard. Or you could go to spring shop and have them re-arced and a leaf added. If you go this way I would get a spring from Junkyard and have the spring shop use that instead of the old one for the fact that the old one is probably pretty shot. How about ordering new springs on line. I saw a part that they mount on the spring side with a screw bolt to help level the side out. I forgot where I saw it but when I find it I will post the site for you. Get new springs and shocks if you plan on keeping it, probanly $400 or so.
MichiganLarry
01-28-2016 06:39 AM
drumminguy81
12-02-2010 07:10 PM
