Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 08-11-2005, 08:51 PM
vancouverpower vancouverpower is offline
Garage is empty, add now
vancouverpower is starting off with a positive reputation.
bio-wvo, questions
Two friends and I want to get away from paying the high diesel prices. I just saw on the news that fuel will be about $3.00 per gallon in a couple months. Currently it's around $2.86.
The three of us are willing to go in together on some sort of system. But none of us know what we should do. I have a 99.5 psd and they both have a 96' Cummin's. And one 68' Kenworth with a Cat. We want something that is hands down safe for all of our rigs. I have been reading some on the different set up's, but don't have any idea on what is going to work for us.
I like the idea of collecting the used fry oil. Is it as simple as filtering it, installing a seperate tank and them warming it up before it is pumped to the motor?
Will this damage the injectors etc? I seem to read alot about people doing it then others will "refine" it themselves to make bio. Why do this if running strait fry oil is ok? Just so they don't need a second tank?
__________________
1999 psd f250 4x4 super cab xlt six speed, bullydog chip, 4" downpipe, 5" straight pipe, kwik filter, level lift kit 35" bfg's, blackcloud diesel ebpv exhaust brake.
  #2 (permalink)
Old 08-25-2005, 03:14 AM
Saigon's Avatar
Saigon Saigon is offline
Saigon is starting off with a positive reputation.
Start here and read,http: //www.greasecar.com/index.cfm , I plan on making my rig from scratch,except the 6 port valve,in september.I have been currently running a 20% canola oil mix without any problems since may.I believe that straight veggie is better than bio,no chemicals eating away at rubber lines and washers,the most important points are filtration and heat,minimum 5 microns and minimum temperature 180°,event the stanadyne IP's will swallow it!
saigon
__________________
1986 7.3l (1989 engine) 4x4 , used to be 6.9 ! Alloy rims, dome lights,
manual switch,Bosch GP's, veggie setup for WVO
  #3 (permalink)
Old 09-01-2005, 12:16 PM
beeglej's Avatar
beeglej beeglej is offline
beeglej is starting off with a positive reputation.
Try this website:
http://www.journeytoforever.org/biodiesel_make.html
Hope This can help.
It did for me.
__________________
1999 F-350 CC SRW AT Lariat 7.3L (444 C.I.) Powerstroke Kwik MOD Bully Dog Power Pup 4" MBPR exhaust
  #4 (permalink)
Old 09-01-2005, 05:51 PM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Just my 2 cents worth, but I've been making biodiesel for about 18 months now, and post on 6 different biodiesel forums. The best and most reliable site I've ever found is http://www.biodieselcommunity.org/onlineresources/ This is a compilation of many sites from around the world, and is THE site to start from. There is a world of experance and many people willing to share there stories. Lot's of help for nube's. I see you are near my location[ arlington or ] If there is any help I can offer just let me know.FABMANDELUX.
  #5 (permalink)
Old 09-01-2005, 07:13 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
simple as that. www.greasel.com
The '96 cummins would be perfect for this. A friend of mine ordered a kit from greasel for his '98 cummins, and it should be here this week. I don't know how well it works in high pressure common rail injection systems on the powerstroke, though.
__________________
Eric
'87 F150 302 ZF 5 speed 4x2
  #6 (permalink)
Old 09-01-2005, 09:55 PM
beeglej's Avatar
the only drawback i see with the straight vegetable oil (SVO) kits is some people just filter it and then put it in their truck.
they don't remove the water which is extremly harmful for injectors
But the water can be removed it just takes a little more time to do.
But overall they are the cheaper per gallon and have a lot less time in processing the fuel.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
