check engine light on 1997 F-150
Hi, i'm new here, so bear with me.I have a 1997 F-150, the check engine light came on, I went to an auto parts store and had them hook up the OBD. It came up with a code, 56, the guy said it was an "input speed circut problem". He went on to list 3 things it could be, Mass air flow sensor, Manifold air pressure sensor, or the Throttle position sensor.
This leaves me with 3 problems. One, code 56 doesn't jive with my code list, two, how do I tell which of the three sensors to replace?Three, do I have to shell out the $$ for all three parts?
Thanks l-m tech, where's a good place to go to get a reliable code read? I'm on a 'tight' budget. I really try to avoid the local dealership because of a bad history with their service dept. Also, does anyone know where the 'Manifold Air Pressure Sensor" is located, my Haynes library manual makes no reference to it? Is it called something else?
trouble code 0301
Originally Posted by trotp3
I got a code that jives w/ my code index....P0301...Cylinder #1 misfire, please tell me its just a fouled plug?! If not, what else might it be, bad plug wire? HELP...Thanks, John
Any suggestions on why my oil gauge goes to 0 while idling at a light and hauling a trailer? I had it checked out by a mechanic who can not find anything wrong with the vehicle. Of course he doesn't have a little horse trailer behind it. My truck is a F 150 with a 6 cyclinder automatic engine with 113000 miles on it. I bought a new oil pressure sensor, but can not get the old one off. Does it require a special wrench? If we get a big enough deep socket to fit the old sensor, the wrench can not fit in the space. Nancy
NLPRacing
29
11-07-2015 05:46 PM
Grinder Man
1997-2006 Expedition & Navigator
10-10-2014 09:35 AM
