Suggestions on Tranny Trouble
Hello this is my first post here but I have already read extensively through the forums, thanks for the good information. My truck is....
1995 Ford F 150 5.0 L 5 speed Manual 4x4
On my last road trip I lost 3rd and 4 th gear. After reading around the forums I believe that my forks are gone on these gears. Before I decide to rebuild or replace I would like some suggestions and opinions from others who have gone down this road. To the best of my knowledge I believe I have the Mazda M5OD transmission. The door jam on the truck says under trans: M. The writting on the side of the transmission says:
F1TA
GC
D816968.
Is this the Mazda POS I read about. I'm considering eventually lifting the truck and swapping to a 5.8W. If this Mazda tranny is a weak POS should I just scrap it and go for a ZF XXXX whaterver.... Any suggestions on a better tranny? Is it possible to get a 6 speed with a granny gear? Could I bolt it in or would I have to do some serious modification? Any suggestions, manufacturers, or war stories are greatly appreciated. One last thing, I would like to thank the ingenious engineer who thought up the location and assembly of the fuel filter. It is such a wonderful easy experience to replace. Thanks for all the help and suggestions.
BERT
F1TA
GC
D816968.
BERT
...Welcome Bert, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Moved and member notified
Enjoy FTE....and
cowchasinsix
20
02-12-2010 01:57 PM
rdhensley
05-28-2002 03:58 PM
